Budget NA6 supercharge build
wade
Postby wade » Sun Dec 28, 2014 9:04 am
Hi all for shits and giggles I installed a supercharger that I had onto my NA6
I believe it is an M45 off a cooper s. I picked it up with all associates brackets etc.
I was going to wait until I had a new engine (current one had SNC issue), fuel reg, intercooler, ecu, injectors etc etc, but since the motor was on its way out I thought why not just bolt it on and see what happens
Here was the result.....
http://youtu.be/6zkXxmzGiVI
To get it to work I took the air flow sensor off the airbox and just joined it to the second throttle body on the supercharger
When I was playing around I found that moving both the throttle bodies together seemed to work better...... But ATM the throttle body is just rigged open.
TBH I'm scared to drive it.......
Noob question for the wiser heads...... Will it go bang?
Can I actually get this to run and drive on the stock ecu (I know that I won't get te best out of the supercharger)?
How do I get the twin throttle bodies to work together?
Any help appreciated.
Re: Budget NA6 supercharge build
Postby NitroDann » Sun Dec 28, 2014 9:37 am
What psi are the pullies?
Do you have 1.8 injectors to swap in?
wade
Postby wade » Sun Dec 28, 2014 9:55 am
EATON M45 Supercharger with 9psi reduction pulley.
Supercharger has Bypass on it as well as nb throttle body. Made to bolt up to na6 head.
I don't have 1.8 injectors.... Will those help?
Postby NitroDann » Sun Dec 28, 2014 10:10 am
Yeah it might survive with the 1.8 injectors. It definitely would with a begi style rrfpr. Don't forget to turn tgebstatic timing down to 6 degreea
wade
Postby wade » Sun Dec 28, 2014 11:21 am
Ok cool I'll get some 1.8 injectors.
Is static timing the same as just doing the timing normally with a light etc? (Sorry if this is a stupid question)
wade
Postby wade » Sun Dec 28, 2014 11:26 am
wade
Postby wade » Sun Dec 28, 2014 12:43 pm
Postby 93_Clubman » Mon Dec 29, 2014 11:31 am
If you can get them for a decent price go for the light purple NB8B injectors, or even the light green 305cc Toyota Supra injectors which the MX5 ECU should handle ok - see following for all details: http://miataturbo.wikidot.com/fuel-injectors
wade
Postby wade » Mon Dec 29, 2014 1:31 pm
Cheers good info
Postby NitroDann » Mon Dec 29, 2014 2:06 pm
I don't know howto calculate rrfpr requirements sorry. Do some googling.
Yes re timing
speed
Postby speed » Mon Dec 29, 2014 3:52 pm
I like it !!!
When I bought my MS2, the guy I bought it off advised that the stock ECU was running as rich as 10:1.
I had always suspected that the richness of the stock ECU would work in F/I provided you knock back the timing, which I was going to do via the j-car module.
Before I knew it, things blew out of proportion and I started going mad buying stuff.
Your pulley looks like it could be a 17% reduction, meaning 10+ psi.
Maybe I'm wrong but looks the same as mine :)
wade
Postby wade » Mon Dec 29, 2014 7:35 pm
Thanks Speed.
I'm not sure that it could ever run on the road like it is..... The noise is crazy, but when it is done I may trailer it to the track to see if it blows up or not
What are you running?
wade
Postby wade » Mon Dec 29, 2014 7:59 pm
NitroDann wrote:I don't know howto calculate rrfpr requirements sorry. Do some googling.
Yes re timing
Will do Dann.... Thanks for the help
speed
Postby speed » Tue Dec 30, 2014 8:46 am
wade wrote:Thanks Speed.
My install is not yet complete but same SC as you. MS2, 320cc injectors, stock SE intercooler with custom pipes. Hurricane extractors, high flow cat, 2.25 exhaust.
Air filter box is the tricky bit due to my lack of space.
Previous owner had it tuned to 109kw atw.
If I wasn't working this week I would have it up and running!!!!
My engine has done in excess of 250 kms and based on the videos my SC is heaps louder than yours. Hoping that bonnet insulation helps otherwise I'm stuffed :)
trader
Postby trader » Tue Dec 30, 2014 11:30 am
I'm running those supra injectors 93-clubman referred to. Works (albiet a little rich with the stock ecu) with the rotrex which is pulling similar psi. Running afpr with standard timing.
NB SE, NA 1.8.
