Everything I touch in my car breaks
Jakeeyjones
Postby Jakeeyjones » Thu Dec 25, 2014 5:26 pm
Hi guys, Ive always loved mx5s but im about done with it.... literally everything i touch in it breaks, rattles and noises from every corner, ive put in more money into the car than what its even worth yet it is in worse condition now than when i bought it. Anyone else ready to torch their car?
M1474
Vehicle: ND - Turbo
Re: Everything I touch in my car breaks
Postby M1474 » Thu Dec 25, 2014 5:43 pm
I try not to touch anything
GHETTOCET
thehillsarecalling
Postby thehillsarecalling » Thu Dec 25, 2014 5:47 pm
Hmmm....is it a case of the car is pretty far gone, or is it a case of it was fine but then it was touched and it broke?
If it's a car is pretty far gone issue - then the choice is to either commit to it 100%, or move it on to another enthusiast who is willing to put the time and effort in. No point in half doing a car as the non-done-half will always annoy you. If you just want a running / driving / no hassle car, sell it off and buy another one that's been well looked after. It will be quicker and probably cheaper.
If it's a skills issue - try getting into your local MX-5 club and shadowing the mechanically experienced guys. Every time I wander into one of the local expert's workshops and spend a day there with them, I learn new ways of doing things that I never would have figured out myself. Kind of like an enthusiast apprenticeship of sorts.
Daily: '91 Malibu - NB8B conversion, 6sp, Teins, Whitelines
Terribly Missed: '02 Black SP (#55)
Plus about 12 others over the years..
doc
Postby doc » Thu Dec 25, 2014 8:06 pm
Don't know what to say Jakeey. Your car is a NA, so it's not a new car anymore. Are things breaking because they're old and brittle, Or is it just a lack of Mechanical know how?
Sorry, don't mean to insult, However, as said before, If the car is too far gone, perhaps time to get a newer one.
badface
Postby badface » Thu Dec 25, 2014 8:22 pm
If you touch something and then it breaks every time. Maybe its not the cars fault?
Wakefield: 1:09.86 | EC GP South: 1:05.55 |
Jakeeyjones
Postby Jakeeyjones » Thu Dec 25, 2014 8:31 pm
the car is definitely on its way out, worst part is that i havnt even owned it for 6 months and since i bought it the diff broke, makes horrible noises all the time, the thrust bearing is stuffed so it always making this loud whining noise, whole gear box needs to be replaced anyway, clutch is slipping, ive had to rebuild the front of the engine as it had crank nose issues and while i was at it decided to fix everything around it, fixed multiple oil leaks, lifters are knocking all of a sudden, recently started blowing smoke when the car is started, ect ect.
worst part is that the car had no issues when i first picked it up, just seems like every thing that could go wrong just did and all at the same time. Its not the way i drive either cause i dont thrash it... definitely think its time to start looking for another one that is abit more reliable.
rossburns
Postby rossburns » Thu Dec 25, 2014 8:51 pm
unfortunately it maybe the luck of the draw, they are old cars, mine is 23yo and now has 186 000 km, but think it was always looked after, but still in the new year it needs a new soft top, they always need some sort of maintenance but that's half the fun :beer: :NA6:
MJT_MX5
Postby MJT_MX5 » Thu Dec 25, 2014 9:20 pm
I've recently acquired my second Mx5 and it just ticked over 200 000k's
My other one is at 94 000k's
And there is a difference, but you must always expect maintenance,
I've found they're a simply car to nut out any problems on and heaps can be learn't on the forum.
Both my cars have all the service history and it shows years on, they both still drive great and i use one as a daily drive.
if you don't want to commit to fixing all the issues, maybe watch the for sale thread and upgrade to a well looked after one that has already had a bit of money spent on it.
Postby Magpie » Fri Dec 26, 2014 9:17 am
Sounds like a case of the dreaded passion fingers disease.
gslender
Postby gslender » Fri Dec 26, 2014 10:21 am
How much did you pay, how many klms when bought and what year is it? The answers can very well explain the problem. Also, what other car (of equal age, cost and klms) is more reliable in your extensive experience?
Postby Mr Morlock » Fri Dec 26, 2014 10:26 am
Cars have a service life. They break when things reach their service life-some things break quicker than others. MX5s are probably somewhat better than most cars but drive an older car and expect things to wear out. There comes a point when it time to change to a set of wheels with lower K's and better condition. Many people also do not want to spend their time fixing cars but instead driving them and doing other things.
Postby Okibi » Fri Dec 26, 2014 2:35 pm
Agree with everyone else, i'm guessing your car is around 25 years old. Any rubber will harden with age and crack or leak, bearings and teeth wear down with use.
Make sure you're running a pretty thick oil, give it lots of time to warm up and make sure the cooling system is working really well. Hopefully the issues aren't too bad.
How many kms on the engine?
speed
Postby speed » Mon Dec 29, 2014 5:19 pm
That sucks dude. The probs you mentioned are all cheap fixes though. Diff, clutch, gearbox. Good luck with whatever you decide.
Rocky
Concerned Citizen.
Postby Rocky » Mon Dec 29, 2014 9:36 pm
Hi Jakee, I was thinking along the same lines as gslender.
A 25yr + vehicle that hasn't been cared for will inevitably have a lot of issues, both minor and major.
I bought a 1976 Celica just like this about 20 yrs ago and the list of things I replaced or fixed was fairly long, but I loved the car and it was worth the effort.
Depends whether you feel this particular car is worth the trouble.
I don't know what you paid but sometimes you get what you pay for.
Anyhow I hope you come up with a plan.
Cheers, Rocky.
taminga16
Postby taminga16 » Mon Dec 29, 2014 11:47 pm
Jakeeyjones wrote:Hi guys, Ive always loved mx5s but im about done with it.... literally everything i touch in it breaks, rattles and noises from every corner, ive put in more money into the car than what its even worth yet it is in worse condition now than when i bought it. Anyone else ready to torch their car?
Let us know where you are, there may be someone who can help you out. We all need a bit of mentoring occasionally.
Greg.
