Clutch Line reroute
madjak
Clutch Line reroute
Postby madjak » Mon Dec 22, 2014 2:43 pm
Has anyone trimmed the clutch hydraulic line at the drivers side of the engine bay and run a short braided line to the slave? It seams silly to run the clutch line all the way to the hot side of the engine bay and then back again across the transmission to the slave.
I would think the cheap braided LHD clutch lines would fit well if the clutch line is cut and flared where it comes out of the master or plumbed directly into the master.
plohl
Re: Clutch Line reroute
Postby plohl » Mon Dec 22, 2014 3:04 pm
Automotive Plus do a braided line that deletes the hard line. It goes straight from the master to the slave. A few other companies do them as well, but you have to be careful with the LHD ones as they're short than needed because they just replace the rubber hose between the hard line and slave - not master to slave.
plohl
Postby Magpie » Mon Dec 22, 2014 3:12 pm
Here is the Automtive Plus stuff viewtopic.php?p=781022#p781022
madjak
Postby madjak » Mon Dec 22, 2014 3:14 pm
Great, exactly what I was looking for ... emailed them already!
Thanks
Postby Magpie » Mon Dec 22, 2014 3:17 pm
Automtive Plus are closed I think till 05/01/15. Just tell them the same as Mark Collingwood's NA6.
madjak
Postby madjak » Mon Dec 22, 2014 5:50 pm
No rush... Would like like to tidy up the engine bay a bit. I had a bit of a spongy clutch last event and I think the metal line got hot as it sits right next to my extractors.
Thanks guys
Postby Magpie » Mon Dec 22, 2014 5:52 pm
I can save you the freight cost and bring it over at the end of January. Before you get excited 25kg limit :)
madjak
Postby madjak » Mon Dec 22, 2014 7:34 pm
you need to start up a MX5 parts exchange... East to West coast.
Unfortunately I don't think a NB subframe could be classed as luggage.
Postby Magpie » Mon Dec 22, 2014 7:57 pm
Happy to do a freight service whilst I'm doing this roster. Must be able to be taken as luggage and no more than 25kg :)
emily_mx5
Postby emily_mx5 » Mon Dec 22, 2014 9:22 pm
I had a custom one in my NA, and one straight from mx5 plus in my SE now.
I love the feel of it, it's a very noticeable difference, hard to explain but it's very smooth with reduced pedal travel. There is minimal movement between engaged/disengaged and take up point, so you can change gears really quickly and easily.
Highly recommended :)
madjak
Postby madjak » Mon Dec 22, 2014 10:10 pm
Didn't think there would be much if any performance gain given the clutch is less pressure than the brakes. I suppose the shorter line with zero expansion makes a difference.
Users browsing this forum: Google [Bot] and 5 guests
