Okibi's SE
Re: Okibi's SE
Postby Okibi » Fri May 02, 2014 2:30 am
Today I received my non AFM BEGI intake pipe.
Here's a comparison between the AFM version and the (old style) non maf version.
As the engine wiggles back and forth this can cause some issue with the fixed intake box. BEGI no longer extend this intake instead they provide a MAF replacement pipe which adds a little wiggle room.
Here is it fitted.
Nevyn72
Re: Okibi's SE
Postby Nevyn72 » Fri May 02, 2014 10:29 am
You're going to have a helluva job trying to spot an oil leak in that engine bay mate! :shock:
I'm a bit confused by the post, you start off by saying BEGi don't make the fixed extended length pipe anymore due to problems this causes with movement of the engine and now supply an extender with some flexibility. You even show a picture of this piece.
However what seems to be installed is the old style solid unit....
Which did you actually get? Was it the old style one as it appears and if so why not get the newer piece with flexibility?
Re: Okibi's SE
Postby Okibi » Fri May 02, 2014 11:25 pm
Even though the older style can cause an issue I still think it's a much neater solution and managed to order one before they changed the design. I'm going to see how it goes.
I had the AFM version before the non AFM version.
Re: Okibi's SE
Postby Okibi » Tue May 20, 2014 3:01 am
Started to fit some offset suspension bushes.
Went to Bunnings and get the bits required to make a DIY tool
Removing the old bush
Pushing the new bushes into place
Juicy HiC
Re: Okibi's SE
Postby Juicy HiC » Tue May 20, 2014 9:03 am
That's a brilliant way of getting the bushes out. They're a bitch of a thing to get out.
Re: Okibi's SE
Postby Okibi » Mon Dec 08, 2014 3:11 am
Sunday was the last event of our club motorsport calendar I was praying for good weather because the tyres were finished.
A couple of gopro frames
Tyres were rooted and starting to fall apart, discovered the front right had a slow leak and needed to be pumped up between runs
The SE as it currently stands
Putting air in the tyres for the drive home
Re: Okibi's SE
Postby Okibi » Tue Jan 06, 2015 1:08 am
Didn't put many updates up last year, haven't done much to the car other than try and learn to drive it better.
I had bought some cheap second hand AO50 225's and was hoping the offset bushes would let them squeeze inside the rolled guards.
Thanks to Shane at Tyreways Bentley for all his help. We had to wind up the suspension to stop them scrubbing but with heavier braking at the track it started to scrub so I raised it a little more.
Re: Okibi's SE
Postby Okibi » Tue Jan 06, 2015 1:09 am
Some photos I shot in the pits at Barbagallo raceway.
Re: Okibi's SE
Postby Okibi » Tue Jan 06, 2015 1:13 am
Back in August I bought a CarbonMiata hardtop. Postage from Brissie to Perth was a killer but the box was this big:
The plan was to collect it from a local depot, install the latches and drive it home on the MX-5.
I got a call from the parent courier company (PEP - Hunter Transport) saying it was too big for the small suburban outlet and I had to pick it up from their main depot. I agreed because it's not that far out of my way and I could get there after work.
When I picked up the hardtop the courier company expected me to take my packaging with me. I thought that might happen but I hadn't accounted for the massive amount of bubble wrap and foam on the inside of the box.
I turned it into a challenge and managed to fit most of the bubble wrap in the boot. The lexan window in the middle of the car and smashed the wooden bits onto small pieces and ripped the box into small bits too stuffing these into the passenger seat, footwell, behind the seats and under the soft top.
I couldn't see out the passenger side or much out the rear so I took all the back streets I could on the way home.
Re: Okibi's SE
Postby Okibi » Tue Jan 06, 2015 1:35 am
Bit by bit I bought all the parts I needed to install the hardtop, forced shutdown over Christmas meant I had some time to install the rear window.
I remember reading Keith's targa Miata post about making a lexan rear window, he used silicon under the polycarbonate and it ended up looking messy.
I decided to use some rubber under the lexan and a bead of silicon around the edge.
I got some motorbike faring domed washers to try and make everything look clean.
Re: Okibi's SE
Postby fastfreddygassit » Tue Jan 06, 2015 11:19 am
Great photos!
Love the CF hardtop.
With the RH17's, the car looks the goods :NETPOINTZ:
Re: Okibi's SE
Postby bruce » Tue Jan 06, 2015 1:12 pm
Good job squeezing all the packaging in tthe car. I bet you will be finding bits of foam in your boot for years.
Roadrunner
coyotes after you
Re: Okibi's SE
Postby Roadrunner » Tue Jan 06, 2015 10:22 pm
Loving that side profile pic in the pits!
(Is that really inside the pits?? Looks like a full egg shell studio!)
MeepMeep
Re: Okibi's SE
Postby Okibi » Tue Jan 06, 2015 11:19 pm
A bit of artistic licence in the editing, here's an example of an image from that night
Re: Okibi's SE
Postby bruce » Wed Jan 07, 2015 10:31 am
Artistic license plate.
