Upgraded Handbrake Shoes
wasabi
Postby wasabi » Mon Oct 27, 2014 4:17 pm
Hi All
Was wondering if anyone new of any options for upgrading the handbrake shoes in my little SE?
Primarily got the car to run in motorkhanas (& some track work) with a heap of motorkhana regulars performing this upgrade. Most do have heavier cars (Think EVO's & WRX's) so not sure if it'll be 100% required for the MX5.
Will have my first motorkhana at the RTDC Round #4 event on November 9th & will run the stock gear but looking for any potential upgrades / advice for the future.
Matt
2004 SE - WASABI Jr - Enhanced by Deckspeed
SMSP Brabham - 2:17.7
SMSP GP - 1:54.4
SMSP Amaroo - 1:04.9
Wakefield Park - 1:11.8
Black_Penguin
Re: Upgraded Handbrake Shoes
Postby Black_Penguin » Mon Oct 27, 2014 4:27 pm
The Mx5 uses the rear brake pads for the handbrake. No separate drum system. You could throw in a set a rear pads with good bite from cold.
wasabi
Postby wasabi » Wed Oct 29, 2014 2:23 pm
Well, you learn something new everyday aye!
I'm so used to cars having a drum for the hand brake, I didn't even notice the MX5 was different!
I'll see how the current pads go in November & see if a change is required :)
SMSP GP - 1:54.4
project.r.racing
Postby project.r.racing » Wed Oct 29, 2014 9:52 pm
upgrade the pad, clamp force or increase rotor diameter.
Smokinscotty
Postby Smokinscotty » Wed Oct 29, 2014 10:29 pm
Given RTDC run on a wet pan, the handbrake doesn't need anything special as the low grip will help break traction relatively easy.
To make life easier, make sure your turned in before reaching for the handbrake and pop a coin in some tape and fold it over the button to make the handbrake "fly off" so while catching the slide you don't leave the handbrake up by mistake.
Have fun out there, they organize pretty fun days out there!
So lets go!
project.r.racing
Postby project.r.racing » Thu Oct 30, 2014 10:57 am
Oh yeah if it is wet. Time to have someone should you weight shifting and decelleration shifting. you may not get it this time. But on the wet is the easiet to learn/do.
kazama
Postby kazama » Thu Oct 30, 2014 11:02 am
[quote="Smokinscotty"]
[quote]
Or get one of these bad boys
wasabi
Postby wasabi » Thu Oct 30, 2014 12:50 pm
Smokinscotty wrote:Given RTDC run on a wet pan, the handbrake doesn't need anything special as the low grip will help break traction relatively easy.
RTDC do run good days... Although I may be biased since I've been an organizer at their days ;) First time competitor, so will be good to be on the other side of the fence this time :)
kazama wrote:Or get one of these bad boys
Drift button is on my wish list... Just a few things ahead of it at present :(
SMSP GP - 1:54.4
Users browsing this forum: Google [Bot] and 192 guests
