what engine for reliable 250-300hp
- Learner Driver
I have a 92 na6 and im wanting to get a reliable 250hp to 300hp. Just wondering if a built 1.8 turbo'd would be alright for that or would i be better off going for a sr20 swap instead. And if anyone knows the cost of building a 1.8 compaired to an sr swap. Thanks
- Learner Driver
Re: what engine for reliable 250-300hp
Thats my starting point. If i had no money restrictions id be aiming a lot higher
Go the SR20 swap. The important question is what is your budget and how long are you planning to take?
- oztrackdays
FAST,RELIABLE,CHEAP ... pick any two.
Key Questions.
Budget ?
Street Legal or Not ?
What does reliable mean to you ? (20-30 hours of operation is super reliable in some worlds)
Budget ?
- zossy1
250whp is easy with basic internal upgrades to a BP (rods, pistons and if you're keen, valve train) and a Disco Potato.
For reliability, add an oil cooler, Boundary oil pump, and a cross flow radiator with a coolant reroute.
This will be cheaper and easier than an engine swap.
- Learner Driver
I will still want it to be street legal. As for my budget ill probably be around 10-12k but thats including diff and driveline etc.
Timeline doesnt really matter though id rather it not be more then a few months.
Thanks for your replies
- davekmoore
LS1
Sell the MX and buy something different.
Unless u want to spend a mint…
- oztrackdays
At the Treads or Flywheel ?
Might be easier to sell yours and just buy an SE they are going backwards in price.
Street legal and in an NA6 you will likely need significant brake upgrades etc ...
LS1 or any engine above 3.0 litres is out for the NA/NB
- A.Chen89
- Vehicle: NB8B - Turbo
Allow 1-1.5k for engineering to make it legal. Turbo b6/bp with Nb8b brakes should pass easily
- Vehicle: Non MX-5
$10-15K is someone else is doing the work.
- Learner Driver
Sweet cheers looks like ill be going with the bp
- davekmoore
or sell NA, buy SE with intake and exhaust already done, replace the turbo, injectors and ECU with proper ones supplied by one workshop who give you a fixed price for the whole job, finished, within an agreed timescale. Stay under 10psi unless/until you do the bottom end and the cooling.
- zossy1
davekmoore wrote:or sell NA, buy SE with intake and exhaust already done, replace the turbo, injectors and ECU with proper ones supplied by one workshop who give you a fixed price for the whole job, finished, within an agreed timescale. Stay under 10psi unless/until you do the bottom end and the cooling.
That's a fair bit more than $10-$12k, even with selling the NA I'd say...
Users browsing this forum: No registered users and 104 guests
