running on 3 cyls when cold.
4sfed5
Vehicle: NA6 - Turbo
Postby 4sfed5 » Tue Sep 30, 2014 7:23 pm
My 1990 na6 runs like a bucket of bolts on cold start up. basically feels like its running on 3 cyls. after about a minute or so its fine and purr like a kitten if seemingly a little rich. the car is turbo and running an emanate blue . but data logs are fine.
bartmanftw
Re: running on 3 cyls when cold.
Postby bartmanftw » Tue Sep 30, 2014 8:20 pm
Your ecu could just be adding too much fuel on warmup
4sfed5
Postby 4sfed5 » Tue Sep 30, 2014 8:34 pm
its not the ecu. full stop. dont even mention it. data logs are rock solid consistant. its a fault with the car somewhere.
Postby bruce » Tue Sep 30, 2014 9:34 pm
Well, let's get out our crystal ball(s). The limited information is not helpful.
Take it to a mechanic.
JBT
Postby JBT » Tue Sep 30, 2014 9:46 pm
4sfed5 wrote:its not the ecu. full stop. dont even mention it. data logs are rock solid consistant. its a fault with the car somewhere.
Well you tell us what it isn't and we'll guess what it could be. :mrgreen:
gslender
Postby gslender » Tue Sep 30, 2014 10:11 pm
It 100% would be the ecu. If datalogs are saying all is ok then the ecu isn't logging ok
Running on 3 cyl would show up on a wideband clear as day.
sailaholic
Postby sailaholic » Tue Sep 30, 2014 11:18 pm
Ecu or no compression when could or dodgy injector.
Ignition is paired so should be running on two or four.
Injector could be sticky when cold but unlikely to be never play up at all ever when hot but every time when cold.
Compression - no ring - head gasket seal when cold? Do a cold compression test and a warm compression test and see if one cyclinder is down.
If it does it every single time when cold pull an injector plug / ignition lead off and see if the revs drop.
Or... It could be the ecu seeing false wide band results until the sensor warms up.... And flooding it with fuel and making it drive like crap.
My bets on something ecu related.
4sfed5
Postby 4sfed5 » Wed Oct 01, 2014 6:26 am
The data logs show injection ms exactly asper logs from when was normal. all other .cu parameters exactly as per old logs when it was fine.
ill do a comp test cold and see what happens.
gslender
Postby gslender » Wed Oct 01, 2014 6:56 am
That's a poor way to confirm that the ecu is fine, but if you think that fuel hasn't changed and all is good with the tune, then it's only spark plugs, coils, injectors or fuel pump. If you had a wideband working we'd narrow it down.
Black_Penguin
Postby Black_Penguin » Wed Oct 01, 2014 12:13 pm
Could be a leaky o-ring on an injector. Fuel leaks around it when the engine is not running and sits in the inlet, it is drawn in at start up and makes one cylinder run rich for a short while.
Postby 93_Clubman » Wed Oct 01, 2014 12:19 pm
4sfed5 wrote:My 1990 na6 runs like a bucket of bolts on cold start up.
Above symptom is typical of a bad coolant temp sensor (to an OEM ECU) on the NA6 - might be an issue if it's still utilised on yours:
4sfed5
Postby 4sfed5 » Wed Oct 01, 2014 3:28 pm
thanks 93 clubman. i changed the temp sensor thinking that might be the issue....it wasnt.
i' think i'm leaning towards leaky injector or head gasket on #1 or #2 cylinder...
JBT
Postby JBT » Wed Oct 01, 2014 4:26 pm
Sticking valve or half dead HLA?
4sfed5
Postby 4sfed5 » Thu Oct 02, 2014 7:37 am
I pulled the injection plugs one by one at cold start. cyls 123 all made it worse. cyls 4 made no difference at all. so the issue is either a leaking injector or a cold compression issue in 4
gslender
Postby gslender » Thu Oct 02, 2014 8:15 am
JBT raises a good point. Stuck HLA could be it
Users browsing this forum: Google [Bot] and 5 guests
