How old is yr timing belt
Aussie Stig
Stig
Re: How old is yr timing belt
Postby Aussie Stig » Tue Sep 16, 2014 1:31 pm
JBT wrote:Another story showing you can't win sometimes :(
Bought a BJ11 Astina new in 2002. It also has a non-interference engine. Cam belt, tensioner, idler, seals etc. were changed at 100,000km as per service schedule.
Four years and just 45,000km later, the (replaced) tensioner spring broke, got into the works between the crank pulley and belt, causing the belt to slip and the valve timing to go out about 180 degrees.
Engine quit, car towed and the whole cam belt replacement process had to be repeated.
Bluddy $5 spring caused just under $800 (parts and labour) worth of repairs.
Triple Bugger!
project.r.racing
Postby project.r.racing » Tue Sep 16, 2014 1:36 pm
Bummer.
Could've been worse. Could've had a SP20 and the the screws from the VICs butterflys unscrew themselves and have the valves and pistons eat them up.
But yes indeed a weird one the tensioner spring going. Newer heard anything remotely similar before.
JBT
Postby JBT » Tue Sep 16, 2014 2:45 pm
project.r.racing wrote:But yes indeed a weird one the tensioner spring going. Newer heard anything remotely similar before.
Me neither, but there you go. It's been my daughter's family car for the last 3 years and it only happened a few weeks ago. :evil:
deviant
Postby deviant » Tue Sep 16, 2014 6:14 pm
Some tensioners get a workout :D
http://youtu.be/5NnMuyifPA4
Gladiator
Postby Gladiator » Tue Sep 16, 2014 6:17 pm
Some of you blokes need to put more bloody miles your bloody Roadsters!! They're no fun sitting in the garage.
Locutus
Postby Locutus » Tue Sep 16, 2014 8:39 pm
Mine is 12 years old and 107k kms.
Have had all the bits to change it, just need to make the time.
deviant wrote:Some tensioners get a workout :D
:shock:
wow.
gslender
Postby gslender » Tue Sep 16, 2014 8:48 pm
Nothing at all like the tensioners in the NA/NB engines. Not even close.
Postby Mr Morlock » Tue Sep 16, 2014 9:20 pm
Ignoring belt replacement is not clever it's pretty stupid.
gslender
Postby gslender » Tue Sep 16, 2014 10:02 pm
Mr Morlock wrote:Ignoring belt replacement is not clever it's pretty stupid.
Nobody said it was clever, just that it doesn't have a material impact to anything other than inconvenience. Stupid is thinking its a bigger deal than that.
Postby Mr Morlock » Wed Sep 17, 2014 10:07 am
a point that seems to have not been noticed. "As nothing is carved in stone when it comes to auto repair, we have seen "interference" engines not bend valves when the belt breaks and we have seen "non-interference" engines bend valves when the belt fails".
It's remarkably naive to think that breaking a belt and disabling a car is not going to represent any more than an inconvenience.Most will take the sensible route and do the maintenance.
project.r.racing
Postby project.r.racing » Wed Sep 17, 2014 10:16 am
That point you have already brought into the conversation. It has been noticed, and you are the only one to agree to it.
gslender
Postby gslender » Wed Sep 17, 2014 12:38 pm
I'd go even one further....
1) It is possible for an interference engine to not bend valves - that is just very, very lucky. More likely is that you will bend a valve. But accept that you could have the engine stop immediately at the same time the cam belt snaps and nothing hit anything - just very lucky.
2) It isn't possible for an non-interference engine to bend valves. If you had a valve break or damage it had nothing to do with the timing belt snapping. I can prove that by rotating my cams when any piston is at TDC and never does anything contact with anything. No damage.
If you believe differently, explain technically how you think the valves come into contact with something etc... use your mechanical knowledge of engines to explain yourself.
On the other hand, if you are just basing your view on what you've heard, then stop spreading rumors and FUD - you are making the world worse by being uneducated and encouraging others to think the same as you.
noobee
Postby noobee » Wed Sep 17, 2014 1:15 pm
gslender wrote:I'd go even one further....
I'd have to disagree with point 2.tired valve springs and belts that break when engine is doing 7000 plus rpm will do the trick.
Mick
project.r.racing
Postby project.r.racing » Wed Sep 17, 2014 1:32 pm
just the springs would've done the trick to bend valve. the belt would've broken due to a mechanical failure in the drivetrain.
gslender
Postby gslender » Wed Sep 17, 2014 1:51 pm
noobee wrote:I'd have to disagree with point 2.tired valve springs and belts that break when engine is doing 7000 plus rpm will do the trick.
Mick
Nope. That's a valve spring breaking and damage wasn't caused by the timing belt. A new timing belt installed the day prior wouldn't have stopped that failure.
Try again.
Explain how it can cause damage.
Users browsing this forum: Google [Bot] and 107 guests
