Oil filter re-location
ED_MX5
Postby ED_MX5 » Sat Sep 06, 2014 6:41 pm
Hi all, So I am looking for a relocation kit for my oil filter.
I also have a few sensors that I need to attach.
I have found what seems to be a good relocation kit without hoses that has two ports in it, one for temp and one for oil pressure.
http://www.ebay.com/itm/BLOX-Oil-Filter ... f4&vxp=mtr
But I have also heard that the Thompson kit is good, but it one has one hole for a sensor. Though apparently you can buy an adaptor that srews between the relocation hoses to mount an adaptor in.
Like this:
http://www.ebay.com/itm/130762709100?_t ... EBIDX%3AIT
If it's a good quality kit, I would probably prefer the first one, I just need to find where to buy the right hoses.
Anyone got any for or against on either of these kits?
Thanks.
-PRAISE THE LOWERED-
Re: Oil filter re-location
Postby Lokiel » Sat Sep 06, 2014 7:38 pm
I'm wary of the eBay oil filter kits. The Blocks tend to be solid billet aluminium blocks which seem OK but the fittings/barbs are cheaply made and prone to leaks (the barbs are incredibly light and feel cheap). I think if you bought decent fittings/barbs, such as SpeedFlow or Aeroflow, they'd probably be OK though.
If you're buying a kit, you may as well get one that accommodates the 2 sensors.
deviant
Postby deviant » Sat Sep 06, 2014 7:38 pm
You can buy everything you need in Australia...No Need to spend $160 just on the filter blocks.
I made my own set of braided hoses for my car after reading a few online tutorials but for an easy life I will use pushlock fittings and rubber hose next time.
These guys are great for this kind of thing: http://www.vpw.com.au/Category/Index/20
speed freak
Postby speed freak » Sat Sep 06, 2014 7:56 pm
The Works Engineering one from mania is great, got one on my nb8b and reasonable price too, comes with everything you need and great quality.
Postby manga_blue » Sat Sep 06, 2014 8:09 pm
One of the most popular reasons I've seen for early retirement at track days has been burst/leaking filter relocation kits. I think I've now seen six unhappy punters pack up and limp home early with oil all over their engine bay.
ED_MX5
Postby ED_MX5 » Sat Sep 06, 2014 8:15 pm
Lokiel-So maybe if I just bought that block and buy different high quality fittings it should be ok?
I can't see how they could stuff up the block, but I completely get the fittings side of things.
Deviant-I have emailed them to ask about what parts I will need to build the kit I would like.
As their basic kits don't have two ports. Hopefully they can help me.
I guess we'll see what comes out on top. Thanks for the input.
Postby Lokiel » Sat Sep 06, 2014 8:28 pm
ED_MX5 wrote:Lokiel-So maybe if I just bought that block and buy different high quality fittings it should be ok?
My answer here is "probably". Without actually seeing the block I can't confidently recommend it which is why going with a quality unit is worth the extra $$$.
ED_MX5
Postby ED_MX5 » Sat Sep 06, 2014 8:40 pm
Yeah good answer, I normally don't go for much ebay stuff. But this one looked kind of decent.
Guess the proof is in the pudding sometimes. I am looking at another kit too, I'll just weigh up the costs and decide which way to go. Whether to chance it an possibly save some money and still get a good kit, or just buy outright top of the line.
rascal
Postby rascal » Sat Sep 06, 2014 9:45 pm
They could make the block centre too thin such that the threaded adaptor hits home before the block touches the base on the motor..Dont ask me how I know this one...:evil:
Now have a Works Engineering one and it fits exactly as it should..
ED_MX5
Postby ED_MX5 » Sat Sep 06, 2014 9:51 pm
^^ Point taken
Nevyn72
Postby Nevyn72 » Sat Sep 06, 2014 11:41 pm
The eBay one looks to be the same as the one I installed.
It took four complete re-installs before I finally got it to stop leaking.....
2 problem areas,
- the o-rings between the engine side fitting and the block would leak.
- and where the hoses fitted into each end block, the hoses would come loose.
If I was to go again I'd probably get the Thompson.
Postby Mr Morlock » Sun Sep 07, 2014 1:32 pm
if you weigh it up its not worth doing. Why move it - just because changing a filter is a bit tricky to remove every 6 months. They say you should be able to remove the filter by hand if its not over tight. As manga says if you do have a failure it would prove to be a poor investment.
deviant
Postby deviant » Sun Sep 07, 2014 5:23 pm
He has sensors that need somewhere to tap in for oil pressure and temperature.
For a road only car I would not bother but for a track car where you are doing an oil change every other event having the filter in a really easy location is well worth it. Track cars are labour intensive things so anything to make life easier!
ED_MX5
Postby ED_MX5 » Sun Sep 07, 2014 9:55 pm
^ Ain't that the truth. Yeah, I need somewhere to put my sensors. and that just made the most sense. Also, as I will be tracking it I do want something easy to do my oil changes as deviant said.
Plus, my JDMWATTS increase with a remote filter.
greenltd
Postby greenltd » Mon Sep 08, 2014 6:47 am
I'm not sure what all the fuss is about. I find my filter one of the easiest I ever had to change.
