Worthy of a hyundai /Lexus badge ?
Some reports are saying no glovebox ?
I like the wheels and gauge cluster.
Not convinced
gslender wrote:Mmmm.... really not sure.... let's look at the details....
[list]
[*] Sept 2014 a world wide release for a car that is targeted for sale in 2016 (WTF?)
I'm not all that impressed and given the original car was considered "great" mainly due to the break-away from traditional (at the time and mentioned so by Derek) and now known because of the Jinba ittai balance, this release seems to be only focused on the image... oh boy.... did that global launch capture that???
I'm not all that impressed...
gslender wrote:Where is Mazda getting their experience with EPS from?
gslender wrote:Not sure if this has come up, but apparently the ND will have EPS (Electric Powered Steering) and the one major downfall with this over Hydraulic, is that you need a computer to help simulate/emulate/manage wheel feedback, friction and dampen the power steering inertia (things that aren't needed or as much of a problem with Hydraulic and/or manual non-powered). To do that you need an array of chassis sensors—monitoring velocity, yaw, lateral acceleration, plus all the usual engine / gearbox / pedal sensors and the smarts needed to bring that all together to cancel out the vague/dead feel that EPS can provide when not done correctly.
The 86 has EPS and so does any new model of car, but obviously to get that good feedback you have to spend $$ on the engineering and be aware of the problem and have had runs under your belt in that space.
Where is Mazda getting their experience with EPS from? It would seem the Mazda 3 is where its at... http://www.caradvice.com.au/241650/2014 ... -steering/
I think the first test drives will be a make it or break it for the new platform.
