GSlender's Track Beeotch!
gslender
Re: GSlender's Track Beeotch!
Postby gslender » Mon Sep 01, 2014 11:15 am
Started building the balsa-wood air box template - it is actually a fairly therapeutic process such that I'm actually really enjoying it.
One thing I'm unsure about, does anyone know what volume or distance of air I should be allowing around the trumpets? Is it a simple case of more = better?
Obviously as the box gets bigger, it becomes more likely to foul on things and generally become a pain with engine vibrations/rocking allowing the box to come into contact with other items, as such there is a desire to keep it reasonable and reduce size unless need/of value etc.
So knowing the optimum space around the trumpets (as a general goal) would be good to know.
G
plohl
Postby plohl » Mon Sep 01, 2014 11:23 am
G, generally bigger is better. I think Prof G.P Blair has some articles about plenum volume in racecar engineering that you might be able to find. IIRC 6x engine capacity or more would give the best results. I am not really sure how much difference it'll make on a street car though, most of the data I have seen has been for FSAE or formula cars with restrictors.
p.s. post more photos :P
plohl
Postby Magpie » Mon Sep 01, 2014 11:48 am
From my conversations with Patrick at Competition Systems you need at least 20 mm from the top and sides of the trumpets to the air cleaner.
This is also mentioned on the Pipercross website "Remember to leave at least 20mm between the end of the trumpet/carburettor inlet and the inside of the filter." http://www.pipercross.net/pipercross-px600-twin-carburettor-air-filters_p24039543.htm
gslender
Postby gslender » Mon Sep 01, 2014 8:43 pm
Flex E85 sensor installed. Now just need to wire to the ECU
Dweezle
Postby Dweezle » Mon Sep 01, 2014 8:53 pm
Awesome!!
Looks so neat.
Would this work with one of your MS2's??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
gslender
Postby gslender » Mon Sep 01, 2014 9:06 pm
Dweezle wrote:Awesome!!
Looks so neat.
Thanks
Yep, any MS2 or MS3 with current firmware will work with the sensor and adjust fuel/spark in accordance with ethanol levels in the fuel.
That's the theory. I'll be keen to configure, fill up and determine if indeed it just works or if the reality is not as smooth.
G
Dweezle
Postby Dweezle » Mon Sep 01, 2014 9:10 pm
Great!!
I am hoping something like this would allow me to run boost safely on my high comp B6 in th future.
Jeremy Clarkson
sailaholic
Postby sailaholic » Tue Sep 02, 2014 7:15 am
Noooo grant that's airbox space there!
gslender
Postby gslender » Tue Sep 02, 2014 7:36 am
sailaholic wrote:Noooo grant that's airbox space there!
Not really, unless I was going to cut into the frame supports, the box can't easily take into that space.
gslender
Postby gslender » Tue Sep 02, 2014 9:06 am
Ok, getting close and just the little fiddle bits to do.
Like the clutch reservoir line. I need to make a cut in for it so I can raise the box and centre over trumpets.
plohl
Postby plohl » Tue Sep 02, 2014 9:25 am
Looks good G!
plohl
Postby Magpie » Tue Sep 02, 2014 10:47 am
Sticking with the 40mm trumpets?
gslender
Postby gslender » Tue Sep 02, 2014 11:06 am
Magpie wrote:Sticking with the 40mm trumpets?
For now. It drives well as it is. I might look at adding 10mm by just spacing out the airbox and making up some spacers etc. longer screws etc.
toppertee
Postby toppertee » Tue Sep 02, 2014 2:14 pm
Nice......
You going to have a crack at alloy welding?
Postby Magpie » Tue Sep 02, 2014 2:19 pm
Sheet metal and brazing would be the limit of my skills.
