Painting Valve Cover
Re: Painting Valve Cover
Postby hks_kansei » Sat Aug 23, 2014 8:30 pm
^ agreed.
I'd be sanding the paint off the hose fittings.
And I'd also be removing the paint from the gasket valleys.
Dupain
Postby Dupain » Sun Aug 24, 2014 12:24 am
Lokiel wrote:Turned out great but please re-consider painting the lettering and do them black.
Also, you shouldn't paint hose barbs, it makes fitting hoses a bit harder and you risk getting paint flakes in the hose.
Prefer a uniform finish and not to over do things. 95% happy with the result. The wrinkle paint for some reason as you can see from the pics did not wrinkle as well along the sides between the cams.
Postby Mr Morlock » Sun Aug 24, 2014 8:47 am
The designer of the engine upgrade for the first NA deliberately left the cam cover unpainted because he thought some enthusiasts would like to polish the cover.
