Blank off egr valve
vfrpete
Blank off egr valve
Postby vfrpete » Thu Aug 21, 2014 7:04 pm
Thanks in advance, is there any benefit in blanking off the egr valve on a stock 2001 nb ?
sailaholic
Re: Blank off egr valve
Postby sailaholic » Thu Aug 21, 2014 7:05 pm
Is there an egr valve on Australian delivered nb?
speed freak
Postby speed freak » Thu Aug 21, 2014 7:45 pm
yes
Roadrunner
coyotes after you
Postby Roadrunner » Thu Aug 21, 2014 9:14 pm
I did some research a while ago on what the EGR system does, there isn't any benefit of blacking it off. Its only open at cruising speed to double burn the exhaust gas, this lowers emissions and it does also increases fuel economy (that's good hey!)
When you go anywhere near pushing the throttle in it closes off so does not effect performance at all, especially full throttle.
Deleting it won't give more horsepower.
Unless you have a specific reason to delete it, I would leave it alone. Plus EPA/police won't be too happy if you mess with the emissions system.
MeepMeep
vfrpete
Postby vfrpete » Thu Aug 21, 2014 9:15 pm
Sure is
and1
Postby and1 » Thu Aug 21, 2014 9:23 pm
I removed the EGR system on my car when I rebuilt my engine.
The EGR port in my intake manifold used to get really gunked up.
Also would you not increase the likelihood of detonation recirculating the gases?
So not so much of a performance gain, more so a way to further protect the engine
2005 Velocity Red MX-5 SE
Garage thread
Roadrunner
coyotes after you
Postby Roadrunner » Thu Aug 21, 2014 10:17 pm
This is worth a read. Explains it all quite well.
EGR gets a bad rap from the poor designed systems in the 70s/80s.
http://www.tuneruniversity.com/blog/201 ... you-money/
"The EGR valve does not open under heavy load (I am unaware of any exceptions) and therefore, you will not be burning exhaust gasses while at wide open throttle. The idea that it somehow hurts power is simply yet another forum myth based on the thought that it “always” mixes noncombustible exhaust gasses with the air/fuel mixture – but it doesn’t."
But your right, it is still exhaust gas so you do need to clean the valve every now and then.
MeepMeep
Roadrunner
coyotes after you
Postby Roadrunner » Thu Aug 21, 2014 10:25 pm
Also depends what you use the car for too.
If you daily drive or do a lot of long journeys it will help your fuel economy.
If you mostly track/race etc you may as well remove it as it isn't doing anything anyway (closed) at load or full throttle
MeepMeep
Users browsing this forum: No registered users and 75 guests
