Welded Diff?
hoffydoodle
Welded Diff?
Postby hoffydoodle » Thu Aug 21, 2014 1:22 am
Anyone here welded their diff for track or drifting?
Is it recommended? (I want to go down a drifitng path with the mx5)
Any issues associated with it?
Thanks in advance!
speed
Re: Welded Diff?
Postby speed » Thu Aug 21, 2014 9:29 am
Fine for track. Illegal for road use though.
oztrackdays
It can be faster but requires higher driving skills.
Postby oztrackdays » Thu Aug 21, 2014 11:38 am
Mine is welded and it probably costs me time, but all the tame racing drivers it will help.
It is cheaper, a full legit spool will be better again, save some weight and be stronger.
Re: Welded Diff?
Postby hks_kansei » Thu Aug 21, 2014 3:02 pm
It will remove any difference in wheel speed, so no inner wheel spinning ever.
But, a weldy can also encourage understeer since the lack of wheel speed difference can try to push the rear in a striaght line while the front wheels try to turn the car.
Clutch pack diffs can also do this, but by their nature they can unlock under certain circumstances (depending on setup etc)
Basically, you'd be better with a clutch pack LSD, but a weldy is cheaper.
speed
Re: Welded Diff?
Postby speed » Thu Aug 21, 2014 7:43 pm
Hoffydoodle, what model mx5? Your model states non mx5.
hoffydoodle
Re: Welded Diff?
Postby hoffydoodle » Sat Aug 23, 2014 12:58 am
speed wrote:Hoffydoodle, what model mx5? Your model states non mx5.
Yeah I need to update. I have a nb8b
Users browsing this forum: No registered users and 83 guests
