Leather seat restoration or replace...
MXMatt
Re: Leather seat restoration or replace...
Postby MXMatt » Sat Jun 28, 2014 4:52 pm
+1 for Leatherique
BRILLIANT STUFF - if you follow the directions and allow the rejuvenation oil to penetrate well then very easy to clean and maintain.
M@
greenltd
Postby greenltd » Sat Jun 28, 2014 5:57 pm
I think that seat is too far gone, the stitching is letting go. I'd be seeing someone about fixing the while seat. It actually looks better than my NA seat. I'm of to discuss options for repair of mine on Monday
Sent from my AMID-9743G using Tapatalk
Postby 93_Clubman » Mon Jun 30, 2014 12:20 pm
A number of forumites have bought leather seat covers from here:
Clarence Choo, X-Otic leather, Unit 2, 50-52 Delby Street, Silverwater NSW 2128 0408 268 888 or 02 9648 2282, 6am-3pm Mon-Fri.
Or get some made from here:
http://www.ebay.com.au/itm/MAZDA-NA-NB- ... _841wt_691
Or here:
http://www.ebay.com.au/itm/MAZDA-MIATA1 ... 2535wt_929
Keith
Postby Keith » Tue Jul 15, 2014 1:12 am
The Leatherique is brillliant. Have a look at its website. The fillers supplied will repair all those cracks. Dyes and refinishing products they suply will make the repair invisible. But if the stitching is gone, you will need to remove the leather cover ( takes about half an hour) and get it restitched to the fabric backing pad. There is nothing complicated or expensive about doing this. The cover can then be easily reattached to the foam/ frame...simple but requires patience. Metal hog rings are used, but these days many successfully use plastic wire ties instead. I did and have had no problems . I recently had a quote from a trimmer to repair one seat at $600!!! I bought covers from the USA and did both seats for well under that in a weekend.
O6 Marble white NC ;91 Malibu Gold NA 1800 BP4W;1990 BRG LE hardtop, unmolested, original; 1993 Brilliant Black hardtop, unmolested, restored.
Postby Lokiel » Tue Jul 15, 2014 11:47 am
in the making
Postby in the making » Sat Aug 16, 2014 7:40 pm
Thanks for all the suggestions.
The seats really are too gone to just use a rejuvenator.
Got a quote for $750 a seat to recover with new foam. Thought it was a bit steep.
So on the lookout for some way to hide the damage, might go with sheepskin!
If anyone knows a good upholsterer in the Brisbane area, I'd love to know.
trader
Postby trader » Mon Aug 18, 2014 11:09 am
I had my Mazda 500 seats rejuvenated professionally -filler in cracks etc. cost a packet but only lasted about two years then the stitching went.Not even sure if it was real leather. If I had to replace my mx leather I would go for the leather covers rather than repair.
NB SE, NA 1.8.
greenltd
Postby greenltd » Mon Aug 18, 2014 9:27 pm
I went to a local trimmer, quoted around $2000 to completely redo my tan le leather seats, in quality leather. Ah, no thanks
Eunos Roadster
Postby Eunos Roadster » Tue Aug 19, 2014 10:11 am
greenltd wrote:I went to a local trimmer, quoted around $2000 to completely redo my tan le leather seats, in quality leather. Ah, no thanks
Hi there,
who was that? Blackmans Leather? I hear they do good work (also soft tops?) but are very pricey?
http://blackmansleather.com.au/
Best regards
Marty
VIC MX5 Club #1912 est. 2012
1991 NA Eunos Roadster Low Budget "Racer"
1989 NA Eunos Roadster BRG Family Resto Project
Postby Mr Morlock » Tue Aug 19, 2014 4:53 pm
Blackmans have a reputation for higher end work.
greenltd
Postby greenltd » Tue Aug 19, 2014 5:28 pm
Not blackmams. A local guy who talked them down, reckons he uses better leather. I know the leather he uses is good as I used to shop where he buys from. As yet I have not contacted blackmans and have only looked at their website which does show good work. I'm now considering other seats, perhaps something like a bride or Recaro which will be better from a support viewpoint than my NA seats. May also be cheaper than recovering. I'll then leave the factory seats in my shed........
in the making
Postby in the making » Sat Aug 23, 2014 9:02 am
$2000!
I was quoted $1500 for the pair; replacing the front facing leather and foam, and leaving the rear/under facing vinyl.
Not keen to spend that kind of coin, so looking for other options now.
Postby 93_Clubman » Sat Aug 23, 2014 11:44 am
greenltd
Postby greenltd » Sun Aug 24, 2014 8:27 pm
Bad link 93...
I'm in two minds, would like to have original seats but would also like seats with better support and comfort. May go and talk to blackmans.
Postby 93_Clubman » Mon Aug 25, 2014 12:09 am
greenltd wrote:Bad link 93...
The links work for me.
