sailaholic wrote:If each cyclinder creates the same volume of gas why would you make one primary smaller?
Because it was longer than the others.
Dupain wrote:plohl wrote:Do you even understand what tuned means?
Gas flow rates to the collector from each outlet. Arrive same time.
Then gas flow rates will be different.Dupain wrote:sailaholic wrote:If each cyclinder creates the same volume of gas why would you make one primary smaller?
nice wiki copy and paste.Dupain wrote:sailaholic wrote:If each cyclinder creates the same volume of gas why would you make one primary smaller?
Extractor manifolds
Most non-turbo performance cars and high-performance four-stroke motorcycles use extractor manifolds, as do most non-turbo racing cars. Extractor manifolds are also available as aftermarket accessories to suit many engines.
Extractor manifolds offer the following advantages over the simple manifolds often fitted to non-performance engines:
Separating the gas flows from the individual cylinders so that undesirable inter-cylinder interference is avoided.
Maintaining an optimum gas velocity by carefully chosen tube diameter.
Allowing the individual cylinders to assist one another by means of the negative pressure waves generated at the collector, where the individual exhausts merge.[3]
This type of exhaust system can be used with or without a muffler, and so can be used on both race and road vehicles.
project.r.racing wrote:nice wiki copy and paste.Dupain wrote:sailaholic wrote:If each cyclinder creates the same volume of gas why would you make one primary smaller?
Extractor manifolds
but changing the diameter of a single pipe alone will screw up theories you just copied and pasted.
sailaholic wrote:The problem is you can't understand. My question is not because I didn't understand extractors. It was asking you to think about your reason for making one tube smaller.
A given volume of air will have an optimum size primary. You then lengthen of shorten primary's to match each other and desired rev range.
Making one tube smaller means non optimum gas flow in that one. This means more restriction so more gas left in the cylinder when the intake charge starts trying to get in.
emily_mx5 wrote:This is so hilarious.
Please continue.
project.r.racing wrote:All I can say from this point on is - get an education.
Users browsing this forum: No registered users and 70 guests
