US Headers & Exhausts NA
Dupain
Postby Dupain » Thu Aug 14, 2014 5:30 am
Do they bolt straight on to our stock catalytic converters?
aka_juffa
Re: US Headers & Exhausts NA
Postby aka_juffa » Thu Aug 14, 2014 9:40 pm
Yes, but you should make sure that you confirm your exact model with the seller as there can be some variation.
J
Apu
Postby Apu » Thu Aug 14, 2014 9:59 pm
There are so many good options locally, why go through the hassle of getting it in from the States?
Dupain
Postby Dupain » Thu Aug 14, 2014 10:12 pm
Thanks J. They are very cheap Apu, and shipping is ok. Just after a 4-1 header and most are 4-2-1.
ralt
Postby ralt » Thu Aug 14, 2014 11:16 pm
Hi.
Just remember most US extractors are to a degree compromised owing to the steering shaft on the left hand side ( the hot side )on Na & Nb and the problems with long primaries and collectors in a restricted space, You would be better off getting onto one of the buying groups and buy from yahoo japan secondhand or source locally.
Dupain
Postby Dupain » Fri Aug 15, 2014 9:13 am
ralt wrote:Hi.
Thoughts are that a RHD header into a LHD car like you said would be a problem and a LHD header into a RHD with the steering shaft now on the left hand side would be ok with the extra room.
Some of these US headers go for $120 US, I suppose they have a bigger market.
Dupain
Postby Dupain » Fri Aug 15, 2014 9:22 am
This was $399, 4-1. I have to fix a leak in my current HSK 4-2-1 item and that will cost @$200 with labour. Needs the flex section replaced, it is an awesome header but the slight leak is annoying and noticeable as you put down some revs initially. Will let you know how it goes in a few weeks time when it arrives. "Should fit". Be good to get a 4-1 to compare.
plohl
Postby plohl » Fri Aug 15, 2014 10:08 am
http://www.ebay.com.au/itm/CXRacing-Header-1989-1999-Miata-MX-5-NA-1-8L-Equal-Length-2-pcs-Vband-/271543748288?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3944c6c0
Those aren't equal length. At all. You can tell by looking at cyl 1 and cyl 4. Cyl 1 should be reasonably straight to the collector, and 4 would be curled up to make up the length. You should have spent you're money fixing the current headers.
plohl
Dupain
Postby Dupain » Fri Aug 15, 2014 11:12 am
plohl wrote:http://www.ebay.com.au/itm/CXRacing-Header-1989-1999-Miata-MX-5-NA-1-8L-Equal-Length-2-pcs-Vband-/271543748288?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3944c6c0
They are tuned.
plohl
Postby plohl » Fri Aug 15, 2014 11:29 am
Do you even understand what tuned means?
plohl
Postby Regie » Fri Aug 15, 2014 11:31 am
No warranty aye.
I see these welds lasting a long time :roll:
slug_dub
Postby slug_dub » Fri Aug 15, 2014 11:55 am
SURE ARE CURLY.
Dupain
Postby Dupain » Fri Aug 15, 2014 3:57 pm
plohl wrote:Do you even understand what tuned means?
Gas flow rates to the collector from each outlet. Arrive same time.
Steampunk
Postby Steampunk » Fri Aug 15, 2014 4:04 pm
"Product Info and Spec:
Header:
1.65" Equal Length Runners"
they have a rather broad definition of "equal length".
Primary that should be the shortest is the longest and vice-versa. :?
Also, how exactly does the secondaries attach to the tertiary?
Dupain
Postby Dupain » Fri Aug 15, 2014 4:07 pm
I'll go a review when I get it.
Don't brush it off because it is cheap and on E Bay. CX Racing has a huge range of products.
The more common 4-2-1 can go for $120.
Users browsing this forum: No registered users and 108 guests
