Dorian Mounting
zossy1
Dorian Mounting
Postby zossy1 » Tue Aug 12, 2014 9:57 am
Hi folks,
Looking for ideas on mounting my Dorian.
I have seen some cool options, including David Stone's nice and tidy passenger side in-floor mounting.
What is everyone else doing? Now I have my own Dorian, I would like something more permanent than my dodgy cable ties through the rear tow hook solution.
Will a Dorian transmit through plywood or plastic? That might allow me to mount it over my undertray or something.
Anyways, would like to hear some ideas :). I do have a couple of those cradles so all I really need is a suitable surface.
Boyracer
MX-5 Encyclopedia
Re: Dorian Mounting
Postby Boyracer » Tue Aug 12, 2014 10:16 am
It goes through plastic and wood, I have just mounted mine on the inside of the front under tray after it got ripped off when it was mounted under the car, lucky I got it back.
plohl
Re: Dorian Mounting
Postby plohl » Tue Aug 12, 2014 11:23 am
I attached the cradle to the circled ridged. Works pretty well, I can easily take it on and off.
plohl
Guran
Vehicle: ND - 1.5
Re: Dorian Mounting
Postby Guran » Tue Aug 12, 2014 7:58 pm
Boyracer wrote:It goes through plastic and wood, I have just mounted mine on the inside of the front under tray.
+1
Mine is on the drivers side with the stock plastic bracket. Very easy to access.
Ned Loh
Re: Dorian Mounting
Postby Ned Loh » Wed Aug 13, 2014 12:35 pm
+1
Pics would be brilliant please!?
Have had a bracket here for ages but haven't mounted it. It would be nice to get it under the car, in a place that is easy to access, but can't be knocked off on a curb or similar...
rascal
Re: Dorian Mounting
Postby rascal » Wed Aug 13, 2014 2:03 pm
mine is also mounted on the front undertray.
Very easy to fit/remove using the $7 mount from dorian industries..
mx5002
Re: Dorian Mounting
Postby mx5002 » Wed Aug 13, 2014 2:52 pm
That splitter looks mad rascal! Is it home made?
My Dorian is mounted to the number plate bracket ..
Because road car! Not race car :lol:
GREEN ITB'd NB8B
Marulan 47.01
Wakefield 1.09.64 :D
rascal
Re: Dorian Mounting
Postby rascal » Wed Aug 13, 2014 3:14 pm
mx5002 wrote:That splitter looks mad rascal! Is it home made?
yep. Just a simple 12mm ply sheet cut to suit..
Ned Loh
Re: Dorian Mounting
Postby Ned Loh » Wed Aug 13, 2014 5:46 pm
rascal wrote:mine is also mounted on the front undertray.
Thanks for the pic. & Yes, looks like a good place to put it.
Re: Dorian Mounting
Postby manga_blue » Wed Aug 13, 2014 7:44 pm
Nothing really beats the passenger floor cut-out if racecar. The ones I've seen just have a plastic box suspended through the floor and riveted and silicon sealed from the road - sorry, no pics.
MattR
Re: Dorian Mounting
Postby MattR » Wed Aug 13, 2014 8:47 pm
^^^ That is also the CAMS mandated spot for racing as well if running in a CAMS category and want to play the eligibility game.
davekmoore
Re: Dorian Mounting
Postby davekmoore » Wed Aug 20, 2014 10:35 pm
Which way is the cradle orientated?
Need pics of mounts with the cradle in position that don't involve cutting the floor please.
Return to “MX5 Motor Sport”
