Hi guys, before I start I just want to point out this is just a project, I have vacuum bleeders and know how to bleed brakes 50 other ways.... Now......
I believe air is escaping from the threads that screw the lid down... What have you guys got or used to seal the master cyl while adding pressure to it?
I'll add pictures ASAP with what I have
Pressure bleeder cap
Re: Pressure bleeder cap
Thread tape ftw !
I don't think that would work due to it having to hold around 10 psi or so
- Vehicle: Non MX-5
10psi is quite low.
but if you have threading issues. then you really need to look at replacing the worn old threaded parts.
I have no issues..... I'm using a pressure bleeder with a modified oem cap.... Just looking for how people seal the master cyl air tight.
Thread tape will work as a temp fix for much higher than 10psi.
Ok cool. I'll give it a go
Users browsing this forum: Bing [Bot] and 384 guests
