glafit HID and Pikaq LEDs
Dupain
Re: glafit HID and Pikaq LEDs
Postby Dupain » Thu Aug 07, 2014 10:51 pm
4sfed5 wrote:you dont need load resistors...you just need to mod the flasher relay. there is a resistor in the relay that is a heap cheaper to replace than load resistors.. just open up the relay. Change the "R1" resistor from a 5.6Kohm to a 1 megohm value...done
Can you expand 4sfed5. Location of relays.
Postby Regie » Fri Aug 08, 2014 8:58 am
the relay will be in the fuse box.
switch the indicators on and what ever one is clicking, that will be the relay you are after
GTR4N
Postby GTR4N » Fri Aug 08, 2014 11:40 am
do you guys watch mighty car mods?
HIDs in reflector housing stand for "Hi Im-a hottie!"
LOL
Garry - Stock white NA8 with cassette deck.
Dupain
Postby Dupain » Sat Aug 09, 2014 9:25 am
How much force would you need to spice. Was 90% through but no impression on the wire coatings.
Dupain
Postby Dupain » Sat Aug 09, 2014 9:27 am
Regie wrote:the relay will be in the fuse box.
Fuse box inside or outside of the car Regie?
Postby Regie » Sat Aug 09, 2014 12:08 pm
Inside
Dupain
Postby Dupain » Mon Aug 11, 2014 8:48 am
Inside
Thanks for your help Regie.
Worked out how to do it. Relay is just about the clutch. Remove it and put in the new resistor like you mentioned. Pulled it out to have a look yesterday.
Smacca
Postby Smacca » Mon Aug 11, 2014 10:24 am
I recently did just this mod to remove 'hyperblinking' indicators from installing LED's.
This link shows you how to locate and remove the car's indicator flasher module: http://www.miata.net/garage/turnsig.html
And this link explains how to change a single resistor within the module to remove hyperblink (some basic soldering is required): http://forum.miata.net/vb/showthread.php?t=335534
The only downside is that if one of your indicators fail, you'll no longer get any hyperblink, which is purposefully designed to notify you of a fault.
Dupain
Postby Dupain » Tue Aug 12, 2014 12:17 am
Guys is this the right resistor? 1W 1MO
Dupain
Postby Dupain » Tue Aug 12, 2014 11:20 pm
Pulled the flasher unit out but the circuit board is firmly placed inside. Any thoughts on removal of the board?
Dupain
Postby Dupain » Tue Aug 12, 2014 11:28 pm
Pull it out with some pliers.
The resistor replacing is the tiny one to the right of the black capacitor.
Dupain
Postby Dupain » Tue Aug 12, 2014 11:37 pm
Maybe, I should get a spare before trying to soldering the new one on. I'm hopeless at these things. Will watch a few youtube soldering videos tonight.
Dupain
Postby Dupain » Wed Aug 13, 2014 1:29 am
Well, I don't know what I did but instead of hyper flashing, it permanently stays on now after the awful soldering effort. Have to manually tap the stalk to make it blink. :cry: :cry: :cry:
Dupain
Postby Dupain » Sun Aug 24, 2014 7:27 pm
Roadie now over. Installed the glafit HID kit today. Could not risk it failing in the wilderness.
Just need to take care not to get the parts in the way of the opening and closing mechanisms. The ballast is water proof and just need a place to secure it.
Thanks to Magpie and others for their help. $50 to under $100 mod depending which kit you purchase.
Pulling out the headlamp.
A bit worn ...
Ballast bolted down ...
I like it! ...
Still to do the hyper flash mod ... not worth it imo ... so no hurry to do.
Dupain
Postby Dupain » Sun Aug 24, 2014 8:12 pm
Just notice one of the head light motor is hot. Any thoughts?
Users browsing this forum: No registered users and 144 guests
