How do I put this wheel together?
GTR4N
Re: How do I put this wheel together?
Postby GTR4N » Tue Aug 05, 2014 9:17 am
Are you serious? An aftermarket steering wheels couldn't be any more straight forward which is why they don't bother with instructions... But good to hear you figured it out in the end
Garry - Stock white NA8 with cassette deck.
Postby Magpie » Tue Aug 05, 2014 9:22 am
The Heineken will not help get the job done :)
ManiacLachy
Engaged
Postby ManiacLachy » Tue Aug 05, 2014 9:24 am
Beautiful wheel :wink:
jimmy_vee
Postby jimmy_vee » Tue Aug 05, 2014 10:01 am
The horn button goes on the outside, this will hold the black ring in place too so you won't need to add any adhesives to it. Those metal rings are adapters so that you can use a Momo style horn button.
jimmy_vee
Postby jimmy_vee » Tue Aug 05, 2014 7:07 pm
Ummm...... there's not really much to know.
• Bolt hub to car.
• Bolt wheel to hub.
• Sit trim ring in place.
• Connect wire to horn button.
• Whack horn button into place.
ED_MX5
Postby ED_MX5 » Tue Aug 05, 2014 8:29 pm
Magpie wrote:The Heineken will not help get the job done :)
True that....
Should have bought a Crown or Corona. :lol:
-PRAISE THE LOWERED-
aka_juffa
Postby aka_juffa » Wed Aug 06, 2014 8:24 am
You do realise that you will have to remove the horn button and clock spring in order to install the new wheel? :D
Notice wheel by the way
J
