Italian tune up!
- Vehicle: NB Roadster
Italian tune up!
Italian tune up;
An Italian tuneup usually refers to a process whereby a motor vehicle engine is run at full load for extended periods in order to burn carbon buildup from the combustion chambers, spark plugs, and exhaust system.
It is performed after a traditional tuneup and often accompanied by an addition of fuel system cleaner to the fuel tank.
This can also be performed before each oil change interval with the addition of a good quality fuel system cleaner, then a few redline runs under load, after the engine has reached operating temperatures.
Most carbon will escape through the exhaust but traces will find their way to the oil pan, hence doing so just prior to an oil change.
It is particularly useful for vehicles that are only operated at low speeds on short journeys, but can help any vehicle to run cleaner longer, and for diesel vehicles prior to emissions testing. Driving for 20 km is typical.
WINTON PB - 1:57.4000
- fastfreddygassit
- Waitin' for a mate
Re: Italian tune up!
narita wrote:Italian tune up;
That is a very dated process, hence why it is referred to as "Italian Tune up", from when Italian cars were being constantly fettled.
Most of us here use SUEC SA459 which, like the aforementioned tune up, is conducted prior to an oil change.
You should give it a try. Enhanced fuel efficiency is one of the outcomes of using SUEC SA459.
We thank you for your contribution though.
when you write these things I think the idea is to actually put it in quotes "..." or make a reference. It's straight from Wikipedia. Wiki also list their references.
Is suec sa459 like Subaru upper engine cleaner?
I just use water dose the same and cost nothing
Sweet I'm still current then.
Water! Lol, i heard powerade gives more hp, especially the red one. Hahaha
- malibu Q
Do you use the add to tank version or the aerosol? I'm thinking the fuel tank additive is easiest.
Sent from my iPad using Tapatalk
I use the spray stuff thru the throttle body. If you read the article you will see that they are different.
speed wrote:Sweet I'm still current then.
Water whats so funny look it up
i agree i think water is also fine.
i for one would stay away from any snake oil fuel additives.
i have used subaru upper engine cleaner which is available at the subaru dealers service department.
it was a night and day difference for a car like mine which rarely gets an open run.
- MXMatt
We use the Subaru stuff when we have cars come in the workshop with "Issues" and it is brilliant gear! but make sure you start the car outside - I usually use a dose of both in a new second hand car when I am baselining it - just to be sure - around $12 - $14 a tin from memory
M@
M@
- ED_MX5
3 Bond also do an upper engine cleaner. Replica of Subaru one. Very popular with workshops I sell to at my work. Part no: 6601j-240 if anyone wants it.
Available at most good parts stores.
They also make one for diesels if anyone has a diesel as well.
Memory on part number not quite so good on that one.
-PRAISE THE LOWERED-
- SuperMazdaKart
Nulon also makes their own version too http://www.nulon.com.au/products/Aerosols/Foaming_Air_Intake_Cleaner/#.U9-RvPmSxYw
- ED_MX5
I almost mentioned it. But its not actually the same stuff. AIC is more aimed as a stronger throttle body and plenum cleaner.
the 3 bond and subaru stuff cleans throttle body, plenum, piston crowns and valves. It really does clean the whole upper engine hence the name.
Users browsing this forum: No registered users and 71 guests
