Exocet Build 001
Moderators: timk, Stu, -alex, zombie
- tinsfci
- Vehicle: NA - V8
Re: Exocet Build 001
Looks great. Got a part number and brand for the headlights?
Street='94 with FFS Coldside. Sold
Race='97 with AVO (soon to be Absurdflow) and GT2560 <--- sod that... LS1 conversion underway!
- Vehicle: ND - 2
They're not headlights. They're parker/front position indicator.
This is a really nice looking piece of gear.
Has anyone investigated the situation with registering under SA laws?
Daily: '91 Malibu - NB8B conversion, 6sp, Teins, Whitelines
Terribly Missed: '02 Black SP (#55)
Plus about 12 others over the years..
- Vehicle: ND - 2
SA rego requirements are the same as any clubbie kit build. I supply the kit with B&T test cert, so providing you stick to the ADR, you won't have a problem with rego.
- Vehicle: ND - 2
IM240 passed today with my 185000km OEM cat converter
- Vehicle: Non MX-5
Exocet Australia wrote:IM240 passed today with my 185000km OEM cat converter
does that mean you can put number plates on it?
- Vehicle: ND - 2
Not yet. Heading for engineering tomorrow
- Vehicle: ND - 2
Aaaaannnnnnd PASS
- Vehicle: Non MX-5
does that mean you can put plates on it now?Exocet Australia wrote:Aaaaannnnnnd PASS
- Vehicle: ND - 2
No. The frame has passed engineering which means that they are registerable. My cars abs isn't functioning, so failed the brake test. It's going through noise tests now.
Absolutely smashed the lane change test
- Bauer
great to hear
Does "passing engineering" include the B&T test? If so, what sort of numbers, or does the test stop at a pass mark?
cheers
Stu
Stu
- Vehicle: ND - 2
Bauer wrote:great to hear
Sorry Stu, just got home from Orange.
We didn't do a B&T test, because:
A- the hole centre's on the test rig weren't drilled out to the right PCD
And B- we're not really worried about it. We have the FEA Analysis results from Exomotive showing 5000nm/deg, and the results are usually right.
Australian Standard has to meet/beat 4000nm/deg
- Vehicle: ND - 2
Hey Matt,
Are you trying to get the car through the brake test with abs ?
none as yet - looking for a white NA8
- Vehicle: Non MX-5
Boost wrote:Hey Matt,
Exocet Australia wrote:No. The frame has passed engineering which means that they are registerable. My cars abs isn't functioning, so failed the brake test. It's going through noise tests now.
What gave it away?
Return to “Engine swaps, Exocet, Locost & MX-5 kit cars”
