Oil sampling makes sense when the engine costs $15,000 but a used NB engine with low klms is $1500 fitted, so I'll just swap my oil after every track day and take my chances. Obviously if I was thinking of hitting 8000 rpm on a regular basis then my used NB would fly apart regardless of the oil and tests, so, as always it depends.
Sent from my iPad using Tapatalk HD
NA8 rear brake pads (does it even matter what brand I use?)
- gslender
Re: NA8 rear brake pads (does it even matter what brand I us
Oil sampling cost is around $35 a time.
- gslender
Magpie wrote:Oil sampling cost is around $35 a time.
Wow, including the removal, sending, advice and assessment on what it means... that's good value. Who are you using?
gslender I'll find out for you.
However have a look here:
http://www.oilcheck.com.au/
http://www.e-monitor.com.au/
http://www.williamadams.com.au/Equipment%20Management/SOS%20Scheduled%20Oil%20Sampling/Pages/S.O.SShop.aspx No prices, but industry standard Cat SOS kits.
Users browsing this forum: Bing [Bot] and 345 guests
