Hi All,
On my little MX the PO mounted the full size number plate in the open mouth, I would rather move it back to the original position which I assume is on the nose center to the car???
Does anyone have a picture of the original mount or selling one?
M@
Number {Plate Mounting (Front)
- MXMatt
Re: Number {Plate Mounting (Front)
Drill two holes at the bottom of the front plate and keep the current mount. The original mount is horrible!
- MXMatt
Thanks EMX005,
I am switching to a slimline plate for the front and really wanted to mount it on the bar, short of just drilling holes in the nose, I was trying to find out how the originals were mounted
M@
M@
you can mount a slimline plate in the nose and use the standard bracket invert it- and its a big improvement over having the thing suspended in front of the bodywork. My recollection was to use an aluminium rhs piece as a spacer to position the bracket / plate - drill holes in the alu rhs and use the same mount points as the original. It does not interfere with cooling. Take a look - have a bit of head scratch make a cup of coffee and its an easy job.
- MXMatt
Thanks will do just that next weekend maybe - I also want to add Fog lights in the mouth and was concerned with air flow / overheating
M@
M@
- Vehicle: ND - RF
You want one of these!
(top one in the link, from either Mania (linked) or Automotive+ in Qld)
http://www.mx5mania.com.au/product1825.htm
This is what it looks like fitted.
- KevGoat
MXMatt wrote: - I also want to add Fog lights in the mouth and was concerned with air flow / overheating
M@
Noooo!!
Looks awful! First things I removed when I got mine home ....
the trouble with that mounting is that a minor push on the plate can end up scratching / damaging the paintwork.
- smy0003
Mr Morlock wrote:the trouble with that mounting is that a minor push on the plate can end up scratching / damaging the paintwork.
Yep, the last thing you want is a scratch on the nose of your car, found out a bit too late though.
Mine's offset now:
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
- MXMatt
LOL Thanks guys,
The way it was previously mounted has damaged all the paint at the lower edge of the opening, (Gives me an excuse to repaint the bar when I get a lower lip!) - the one shown by Nevyn72 is exactly what I am after! many thanks
I drive over 125klm each way to work 5 days a week and through some pea soup fogs for four or five months of the year so fog lights are a safety thing as much as anything else - I was thinking of fitting the lower half of an NB bumper - but that is a lot of work for a similar outcome - now I just have to find some fog light brackets and good to go!!!
M@
M@
- smy0003
I love the look if the lights in the air dam.
Eye of the beholder and all that junk, I guess.
Users browsing this forum: Bing [Bot] and 3 guests
