Which 205/50/15 semi slicks?
deviant
Re: Which 205/50/15 semi slicks?
Postby deviant » Thu Jul 31, 2014 10:47 am
davekmoore wrote:
deviant wrote:Toyo R1R might be worth a look but personally I am not convinced in the value of S-Specs. They are about a second off the pace on track, last 4 laps before turning to grease and then the tread vanishes in a cloud of blue smoke and rubber marbles. They are also about the same price as a proper semi-slick. They do have much better road manners though.
So that's the conundrum. Do I stick (no pun intended) to S specs and look to set a time on, say, laps 2, 4 and 6 only and have decent longevity and road manners or do I go R specs with more $$$, less longevity and a less enjoyable drive on the road in exchange for maybe more quick laps?
I find it incredibly frustrating to drive around tyres like that especially if you only have limited laps. You basically end up treating the tyres like a soft compound slick and have to build up to 1 or 2 flying laps and then back out of it. You don't get in to a flow and if someone gets in the way or you need to let someone go by you lose your opportunity.
You will find that S-Specs don't always have decent longevity on track, especially when they are new with all of the tread on them. The tread blocks squidge around and the tyre overheats and then the corners of the tread blocks start falling to pieces and one decent slide can make a real mess of them. They do not cope with big heat as well as a semi slick.
I also find that the limit of the tyre is less progressive than a semi-slick.
rossint wrote:My experience, NT01 is faster than the R888 in dry, R888 last longer and are faster than the NT01 in the wet. Both come up to temp quickly and don't drop off, even after an hour and a half on the track. I've not had a problem with either of these tyres on the road, sure they're noisier than a street tyre but they can barely be heard over the rest of the car. My car is used mainly for track work, gets dríven to and from the track and the occasional trip to the shops.
This is all true and the same as my experience.
My car is noisy as hell anyway but a semi-slick on the road makes a sort of whirring noise particularly over 80kmh.
The wet weather thing gets people in a flap sometimes. I would not go out if it was raining sideways but I would not worry about it to much...just be respectful and stay smooth, like you would on any tyre. I took a car on the Nurburgring a few months back in the wet and that was on R888's and in fact there were sections of the track it was raining sideways but I managed to not kill myself.
davekmoore
Postby davekmoore » Thu Jul 31, 2014 9:22 pm
Comments on ADVAN A048 in 225/50/15 on Konig "Dial In" 15x8?
Wheel specs say slight roll needed on NB if at least 1.5 negative camber (which I have) with that tyre size, although the A048 apparently fits more like a 235.
The wheel is also available in a 15x9 which will only fit with coilovers (which I have) and is a better fit for a 235.
rascal
Postby rascal » Fri Aug 01, 2014 8:00 am
davekmoore wrote:Comments on ADVAN A048 in 225/50/15 on Konig "Dial In" 15x8?
I wouldn't go near A048s with a ten foot pole. From first hand experience, they are ok for first half a day (once you can finally get some heat in them) but fall of a cliff after that such that by the 3rd track day they are junk, even though tread is still plentiful. Worst track tyres I've ever run. Apparently work ok with heavier cars like IPRA dunnydores, falcons, etc, but on our light cars they are lousy.
Their successor A050s on the other hand are worlds better, and possibly the best tyre out there ATM. Expensive but worth it if tenths are critical. For a better value equation try NT01s. 99% of the speed for 55% of the cost
If going for Dial-ins go for the 15x9 and try for 225/45 rather than 225/50. They fit a bit easier/better.
Note that 9" dial-ins with a +35 offset will only fit if your coil overs have the narrower springs. The larger 70mm dia springs that many coiilovers come with will rub..
davekmoore
Postby davekmoore » Fri Aug 01, 2014 8:32 am
Thanks rascal, and thank goodness for this forum.
The coilovers are Tein Flex. Would 9s work with those? If not, would they work with a spacer, or do I just do the sensible thing and go with 8s?
225/45s still ok if I go with 8s?
RS2000
Postby RS2000 » Fri Aug 01, 2014 9:05 am
rascal wrote:
davekmoore wrote:Their successor A050s on the other hand are worlds better, and possibly the best tyre out there ATM. Expensive but worth it if tenths are critical. For a better value equation try NT01s. 99% of the speed for 55% of the cost
There are vastly different opinions/experiences.
I've had a few people (including MX5 drivers) tell me that A050's are only good for hillclimbs, because they heat up quickly, but are gone after a couple of circuit laps. Maybe there are different compounds.
I've had A048's on an Escort (light car) & they were excellent.
rascal
Postby rascal » Fri Aug 01, 2014 9:15 am
davekmoore wrote:Thanks rascal, and thank goodness for this forum.
TEINs comes with 70mm springs as default. So they will rub with the 9s.
Yes, they will work with a spacer. I think 3mm or something similar..
Personally I would just go with 8s to avoid the hassle of spacers or changing springs.
Depending what tyre you get, 225/45s can be similar to 205/50 in width anyway... (lightyear had an old post where he put 225/45 next to 205/50 (in NT01s I think) and there was just a few mm difference, not the 20mm you would expect from the nominal measurement..
205/50 on 8s (vs 225 on 9s) are an easier fitment, the tyres are easier to source, marginally cheaper and would suffice for your usage. The majority of the vic club run 205/50 on 8s where allowed to. 225s on 9s are ultimately quicker, but depends if you want the added fitment issues for that 0.1 second per lap difference.. Only you can answer that..
plohl
Postby plohl » Fri Aug 01, 2014 9:46 am
You can run 225s on 8s
plohl
deviant
Postby deviant » Fri Aug 01, 2014 10:32 am
Sorry to be off topic...Where are you buying the Konigs from?
TTT
Postby TTT » Fri Aug 01, 2014 11:13 am
Federal 595RSR - http://www.federaltyres.com.au/tyres/ul ... ce/595rs-r
Buy it here
http://tyre-city.com.au/index.php?main_ ... cts_id=271
He is Brisbane based but will ship..
I highly doubt you will find it cheaper elsewhere.
deviant
Postby deviant » Fri Aug 01, 2014 2:24 pm
I always avoided A048's to...everyone I have spoken to say they take far to much management and are not very robust.
R888's and NT01 are hard to destroy with hamfisted fistyness.
davekmoore
Postby davekmoore » Sat Aug 02, 2014 10:21 pm
Relatively conservative Konig "Dial In" 15x8 +25s are now on order.
So tyre options are 205/50 or 225/45.
I'm getting the message that for the track R specs are way better than S specs. Quite liking the Nitto NT01s but concerned about whether they're truly street legal and safe and how long they might last for my part road and part track use. Also concerned about how bad they are in the wet on road and track. Your thoughts?
davekmoore
Postby davekmoore » Sat Aug 02, 2014 10:40 pm
.......... but then some sources say R888s are R spec, whereas others say they're S spec?
beavis
Postby beavis » Sat Aug 02, 2014 10:47 pm
Dave, ive been using the NT01 for ages, dont use them on the road. They dont like standing water.
I was aquaplaning along the main straight of philip island at barely 100kph. Think I was still the fastest in the session.
The R888 is an R spec.
Postby manga_blue » Sun Aug 03, 2014 12:05 am
Pity you don't live somewhere sensible, Dave, like Moruya. I've got a set of R888s, a set of A050s, a set of StarSpecs and a set of KU31s here. You could try them all. :D R888 and NT01s are very similar tyres, both very R-spec, made by the same manufacturer.
R-specs look like this: huge block size, low void ratio, no fancy little patterns to make them quieter, very soft compound (you can drive a fingernail into them), bad when cold, need heat to get sticky, ratshit in the wet;
Image Image Image
S-specs look more like road tyres: harder compounds, much smaller block sizes, many more little cuts on the tread, reasonable grip when cold, OK in the wet:
Image Image Image
davekmoore
Postby davekmoore » Sun Aug 03, 2014 1:39 am
Thanks manga_blue for going to so much trouble with the pics. I confess to feeling somewhat stoopid about my lack of knowledge on this subject but hopefully this info is helping others too.
Each new post helps me narrow things down but also produces more confusion. The Nittos are now ruled out for lack of wet grip. You earlier said the 888s weren't great for road use but I might be prepared to put up with less good road manners for good performance on the track.
To answer a question in an earlier post; no I'm not looking for extra tenths per lap.
