Mx5 turbo for sale, need input
Destijl
Postby Destijl » Mon Jul 28, 2014 3:47 pm
Hey everyone
I found the below turbo mx5 for sale, can someone provide input on this vehicle with regards to it's history?
http://www.carsales.com.au/private/deta ... =6&sdmvc=1
Regards
Damien
Re: Mx5 turbo for sale, need input
Postby Magpie » Mon Jul 28, 2014 4:31 pm
Some good news is the LA3 mod plate:
http://tmr.qld.gov.au/Safety/Vehicle-standards-and-modifications/Vehicle-modifications/Light-vehicle-modifications.aspx
Code LA3 covers the fitting of turbochargers or superchargers not originally offered by the engine or vehicle manufacturer.
MODIFICATIONS COVERED UNDER CODE LA3
The following modifications may be performed under Code LA3:
 Fitting of turbochargers or superchargers not originally offered by the engine or vehicle manufacturer.
MODIFICATIONS NOT COVERED UNDER CODE LA3
The following is a summary of the modifications that may not be performed under Code LA3:
 Fitting of replacement engines already fitted with a turbocharger or supercharger by the engine manufacturer (these are usually covered by Code LA2); and
 Fitting of turbochargers or superchargers that cause the vehicle not to meet the required gaseous emission standards.
Postby bruce » Mon Jul 28, 2014 5:54 pm
Not good news if he's not in Qld.
Destijl
Postby Destijl » Mon Jul 28, 2014 7:18 pm
I live in Brisbane so there shouldn't be any issues, is the Avo turbo kit reasonably good? Also any specific thinks I need to look at when looking at a turbocharged NA?
speed freak
Postby speed freak » Mon Jul 28, 2014 7:42 pm
AVO kits are a good bit of kit, pretty sure this turbo NA was for sale on here and carsales not too long ago but had different wheels, was considering it myself. Pretty sure MX5 Plus had done some work on it, should give them a call tell them the rego/explain the car to them and see if they remember it.
Other then that just look at the things you would normally look at when buying a car. Make sure when it comes onto boost it doesnt stutter or hesitate, check for any leaks, blowing smoke etc check the clutch doesnt slip. I didnt go see it in person but looks like a good package.
davekmoore
Postby davekmoore » Mon Jul 28, 2014 7:54 pm
Just before I dive in with comments about doing the bottom end, is this for sale by a fellow forum member?
Destijl
Postby Destijl » Mon Jul 28, 2014 8:01 pm
How much would it cost to do the bottom end and who in Brisbane can do it?
davekmoore wrote:Just before I dive in with comments about doing the bottom end, is this for sale by a fellow forum member?
davekmoore
Postby davekmoore » Mon Jul 28, 2014 8:21 pm
Several thousand dollars if you want it done right including balancing and extra-strong everything.
There's another car available, later model, with the bottom end done, for $4k more.
Destijl
Postby Destijl » Mon Jul 28, 2014 10:09 pm
Could you provide the link to that car? Is it in Brisbane?
davekmoore wrote:Several thousand dollars if you want it done right including balancing and extra-strong everything.
davekmoore
Postby davekmoore » Mon Jul 28, 2014 11:11 pm
speed freak
Postby speed freak » Tue Jul 29, 2014 5:26 pm
For any work that you want done even an inspection, go to the bottom of the page and click on the Automotive Plus/MX5 Plus link. They are a MX5 specialist in Brisbane, they do exceptional work.
Users browsing this forum: Bing [Bot] and 3 guests
