02 Sensor sockets
prolifik
02 Sensor sockets
Postby prolifik » Wed Jul 16, 2014 2:25 pm
Where in syd stocks these 02 removal sockets ???
they look like a spark plug socket kinda thing but with a slit up the side.
500% need one for my NB SE.
cant get to it at all even if you remove the heat shields.
or if anyone can lend me one? im in st clair 2759
narita
Re: 02 Sensor sockets
Postby narita » Wed Jul 16, 2014 4:30 pm
I have just had some issues with my 01 mx5 o2.
The shop sent me the socket you are referring to, but since you need to access it from in between the gearbox and exhaust you will most likely need the short type tool.
WINTON PB - 1:57.4000
Postby hks_kansei » Wed Jul 16, 2014 4:53 pm
Most places that sell single sockets should also have them.
I think mine came from Repco.
You can try just cutting a slot into a standard deep socket, but there's a good chance that it may splay out and slip once you put a decent bit of torque on there. (the proper o2 sockets are hardened like impact sockets)
or just chop the wires at the socket end and use a normal socket.
sailaholic
Postby sailaholic » Wed Jul 16, 2014 5:48 pm
I just used a spanner, is that not an option?
Postby hks_kansei » Wed Jul 16, 2014 7:44 pm
sailaholic wrote:I just used a spanner, is that not an option?
With 15+ years of heat cycling they get stuck pretty hard.
Open spanners usually can't get the torque needed without rounding the nut. And ring spanners can't get over the wires.
Which is why I suggested cutting the wires, if you're replacing the sensor anyway there's nothing to lose.
sailaholic
02 Sensor sockets
Postby sailaholic » Wed Jul 16, 2014 9:05 pm
Ahh I could get my ring spanner over the plug of the sensor for memory (sensor wasn't factory)
Postby manga_blue » Wed Jul 16, 2014 9:23 pm
Mate, I think you're posting on the wrong forum. This is the car one. :D
sailaholic
Postby sailaholic » Wed Jul 16, 2014 9:33 pm
What do you mean manga? :D
Postby manga_blue » Wed Jul 16, 2014 9:51 pm
Mens health is over at mystuffedprostate.com.
sailaholic
Postby sailaholic » Wed Jul 16, 2014 11:06 pm
Where did you get the idea for prostates from :S
prolifik
Postby prolifik » Sat Jul 19, 2014 12:58 am
lol @ using a spanner...
This is a SE.
its hidden behind the exhaust dump, near impossible to get to.
Ended up getting it just now, tough as buggerey to get to which was the real issue.
ED_MX5
Postby ED_MX5 » Sat Jul 19, 2014 1:02 am
Burson Autoparts sell the socket.
If I remember I'll grab the part number on Monday.
-PRAISE THE LOWERED-
narita
Postby narita » Sat Jul 19, 2014 9:04 pm
damn nb8b, after trying 2 special sockets we had to just use a 22mm spanner due to its location the socket are pointless
