Hi guys just installed the glass window agi bar and lost about 10cm of travel on my bride digo- was wondering what the best seat for comfort would be? Helmet clearance is not of concern at this point.
Cheers mike
Best seat for agi roll bar nb
Re: Best seat for agi roll bar nb
Anyone? How are the sparcos
- tescoking
I have the same problem, and I believed any sparco seat should be able to fit in, just make sure to tilt back the seat to where you like when you do the welding.
NA6 here
NB glass window soft top
AGI roll bar
Sparco Sprint V on stock NA6 rails.
Top right corner of seat touches bar before sliding all the way back.
probably lost about 10cm too.
AGI roll bar
Thanks guys Yeh i was at mania before measuring the sprint V same dimensions tbh. Look like need something with a narrower headrest region and mounted lower
Mayb similar to the Na stock seat which is shorter
Next MX5 = different roll bar
You don't loose any seat travel with the MX5Plus Roll bar (not the Tall Boy).
Sparco fitted and plenty of room for my 192cm.
yeah im abit cut i didnt do my research properly aye - going to get a set of pci v2 mounts from the states - now which seat...
for visual purpose..
NA6
NA6 rails
Sparco Sprint V
AGI bar
I'm 5'10" (178cm ish)
II you've already bought the it I say sell bar to someone who is going to bolt the seat to the floor for track only and get a Brown Davies or Mania or MX5 + ones.
NA6
NA6 rails
Sparco Sprint V
AGI bar
