DIFFERENT ENGINE NOTE???
- Learner Driver
I just put my NA6 in for a service and a tune up as it was running like dog balls.
I get it back, and the whole car under accelleration sounds much more growly instead of smooth and linear...
Is this a possible advance in timing?
Can a simple "tune" do this???
The exhaust note has changed to. I had a fairly raspy exhaust at a certain rpm, and now it hardly does that.
Can anyone explain?
Can anyone explain?
- aka_juffa
Re: DIFFERENT ENGINE NOTE???
New air filter?
Engine is breathing better and sounds more forty.
J
J
Rorty?
It's not a carby... No such thing as a "tune"
Not true Emily. Timing and plug gap are part of a "tune up service" and still apply here.
Just changing a coolant sensor changed the note of my car.
Assuming still standard, have they refitted the airfilter element &/or the airbox snorkel up to the rear pside corner of the engine bay? Or have they possibly removed an old cloth that had been sucked into the airbox snorkel (that's what I found in the airbox snorkel of my old NA6 just after I bought it).
- Vehicle: Non MX-5
running like dogs balls. now running like it should. so the air-fuel ratio has changed. hence diffence in exhaust sound due to combustion being different.
- Vehicle: NB8B - Turbo
Also could have replaced a gasket or fixed a small exhaust leak which would change the sound.
speed wrote:Just changing a coolant sensor changed the note of my car.
Now I have heard everything
- CapitalF
- Vehicle: NA6 - Turbo
Im with chrisearl88 - most likely a physical change related to exhaust. You may also want to check for exhaust / manifold cracks that have suddenly become more pronounced due to tune.
90 Silver Roadster 1.6 + GT2554, large IC, MS-PNP, lightened flywheel, HD Clutch, 2.5" exh, Teins, Whiteline, etc etc
- zero00
emily_mx5 wrote:It's not a carby... No such thing as a "tune"
RUBBISH!!!
Roger D-SUNSHINE COAST
lizard wrote:speed wrote:Just changing a coolant sensor changed the note of my car.
Ke? You don't believe me. Faulty sensor ran rich, new sensor not so rich. Changed sound. What's not to believe?!
speed wrote:lizard wrote:speed wrote:Just changing a coolant sensor changed the note of my car.
- Learner Driver
Wow didnt expect such a vast response!
I havnt got the invoice off the mech yet, as I picked it up after hours...
I most likely would assume that a air filter was replaced, as it has definately changed tone from the front section of the car.
So there wouldnt be any form of timing change from cam gears ect????
Users browsing this forum: No registered users and 72 guests
