How many RWKW do you have with what mods?
david_syd_au
Re: How many RWKW do you have with what mods?
Postby david_syd_au » Thu Jun 26, 2014 11:55 am
speed wrote:I'm green with envy. Amazing how much difference that extra 200cc makes.
I will invent a process that converts your sarcasm into an octane booster, .. then you'll see
2011 NC LE "Black Beauty" (ours) | 2006 NC race car "Shazza" (his) | 1998 JDM NB race car "OMG" (hers) | NC Trailer
speed
Postby speed » Thu Jun 26, 2014 4:52 pm
I was actually being genuine.
Would have to do cams to get similar power from my 1.6
david_syd_au
Postby david_syd_au » Thu Jun 26, 2014 5:44 pm
speed wrote:I was actually being genuine.
Ahh, sorry :oops:. Here, have beer on me :beer:
Mine now has a race exhaust and I plan to redo the tune based on some advice from gslender, so it will be interesting to see the power difference.
speed
Postby speed » Thu Jun 26, 2014 10:00 pm
All good David.
I'd have to be an absolute c&$t of a bloke to start this thread and then bag people out.
Especially when my car probably has the least hp of all the cars mentioned here so far.
Sage
Postby Sage » Fri Jun 27, 2014 11:33 am
speed did you see the plenum? help you at all?
speed
Postby speed » Fri Jun 27, 2014 11:42 am
I did, she is a beauty!
I believe that it was rascal that was asking about it though. Cheers :)
rascal
Postby rascal » Fri Jun 27, 2014 12:12 pm
Yeah, that was me.
Sage, looks like you are running the std throttle body?
If so, would that not negate the advantages of a bigger plenum?
Sage
Postby Sage » Fri Jun 27, 2014 3:23 pm
not sure at this stage as i said i only got the car. i believe its the standard throttle body though it is quite generous intake for a 1.6 at about 75mm. (Not sure what it steps down too within though ive read about 55mm).
On the 1.6 the intake pipe and afm are both more of a choke point. as you can i see i have neither AFM or standard intake pipes to the throttle body..
as i learn more about the car and the tune i may consider moving to a larger one.. though from what i understand the 1.8 has the same dimensions.. and if it can flow a 1.8 im sure it can flow a worked 1.6.
Though happy to hear from someone who knows more about these things. :)
dielle
Postby dielle » Fri Jun 27, 2014 3:28 pm
johnnyreble wrote:What a bunch of tossers .. why can't you just answer the question or have you never been to a dyno..
I've never been to one, despite owning revvy cars such as a Rover 220 Turbo, Alfa 156, RX-8, etc. I'm only interested in improving the handling of a car, not its power. Thus I only think about suspensions and strut bars.
speed
Postby speed » Fri Jun 27, 2014 7:07 pm
If handling is your thing probably worth while considering sway bars, under car braces and bushes too... I highly recommend the wheels, suspension and brake section ;)
Paulus
Vehicle: NA6 - Turbo
Postby Paulus » Wed Jul 09, 2014 1:23 pm
Just dyno'd the car i brought from the UK.
- megasquirt 1
- mini supercharger MP45 with 17% reduction
- 1.6 NA
- boost leak on charger outlet
- 109rwkw
First run, I had part of a CAI plastic flange blocking the pre supercharger TB, which led to 3PSI at redline (!).
here's the result
http://s30.postimg.cc/8jdir9oi9/IMG_5870_1.jpg
td05-16g, megasquirt, custom zorst, msdroid tablet etc
speed
Postby speed » Wed Jul 09, 2014 2:19 pm
Impressive. Bet the supercharger sounds awesome too :)
Paulus
Postby Paulus » Wed Jul 09, 2014 2:55 pm
mate- it is completely ridiculous.
I'm hoping it will quieten down when i change the outlet to a cast from Trlane. hoping for more boost :0
https://www.youtube.com/watch?v=UjQuFdAAaCo
evil_weevil
Postby evil_weevil » Wed Jul 09, 2014 8:29 pm
I won't get into the nitty gritty with the dyno argument, I just answer the original question!
94 na8
Full exhaust, intake, cams and adaptronic
94rwkw
Prior to cams and ecu, so just exhaust and intake it made 75rwkw
4 years earlier on a different dyno made 75rwkw with same mods so not bad
On the 94rwkw best I've done is a 1.11.8 at wakie - I'm not as quick as Lou!
viewtopic.php?f=73&t=62834
evil_weevil
Postby evil_weevil » Wed Jul 09, 2014 8:31 pm
Just on that, as my car is no longer rego'd, how much difference would no cat converter make? If any?
