Zero compression on rebuilt engine
Re: Zero compression on rebuilt engine
Postby NitroDann » Sun Jun 22, 2014 4:44 pm
Remember there are hot clearances and cold clearances so you need to make sure you are calculating for a desired COLD clearance this way.
project.r.racing
Postby project.r.racing » Sun Jun 22, 2014 6:27 pm
valve were closing when you completed head rebuild?
Postby Mr Morlock » Tue Jun 24, 2014 4:53 pm
I would recommend that you read the workshop manual info provided by Manga- not reading all this info may end yup with another prob- personally I think these are the best reference sources. I guess its pretty obvious that the valves are not seating. If after reading the info and you are not confident about doing it then perhaps pass it over to a professional guy.
speed
Postby speed » Tue Jun 24, 2014 9:38 pm
What Morlock said and if you do pass it over please remember to let us know what the problem was. :)
and1
Postby and1 » Tue Jul 01, 2014 3:41 pm
So finally had time to have a thorough check over this.
All the shims were indeed too thick after the new seats for the valves were done.
I had to call Precision Shims to sort out the new sizes. They ended up costing $9.90 ea inclusive of GST plus $12 for shipping. Costly adjustment :roll:
For reference here is my spreadsheet I made to measure the required thicknesses. Current shim thickness is around 3.1ish mm
My required shim thickness was calculated using the depth of the base where the shim sits to the lip of the bucket plus the clearance from the lip of the bucket to the camshaft base diameter (using feeler gauges) minus the required cold clearances for the lifters.
So hopefully the new shims arrive later this week and I can try to put everything back together by the weekend :mrgreen:
2005 Velocity Red MX-5 SE
Garage thread
project.r.racing
Postby project.r.racing » Wed Jul 02, 2014 9:45 am
wow there is quite a large varience in all those.
Postby Mr Morlock » Wed Jul 02, 2014 2:33 pm
As long as the correct methodology was used for the calculation then the shims ordered should be correct.
I agree that its costly but it has to be right - I would have thought Mazda would have a range of shims- apparently not.
On the exhaust range its only about 0.013mm 0.005 thou between the 2.97 / 2.84 shim variations. That variation does not seem much to me
I assume that the shim maker meets the +/-0.03mm / 0.001 tho tolerance stated by Mazda. It might not be a bad idea to check them before assembly.
Lets see how it all goes.
greenMachine
Postby greenMachine » Wed Jul 02, 2014 8:19 pm
Mr Morlock wrote: It might not be a bad idea to check them before assembly.
ALWAYS check the clearances after assembly, and be prepared to replace a few. Odds on you mucked up at least one I know I did. :(
:mrgreen:
project.r.racing
Postby project.r.racing » Thu Jul 03, 2014 8:41 am
Mr Morlock wrote:I agree that its costly but it has to be right - I would have thought Mazda would have a range of shims- apparently not.
Mazda do. And they cost alot more than the above listed price.
Postby manga_blue » Thu Jul 03, 2014 12:26 pm
When I bought from Precision Shims they offered to make to 0.02 or 0.01mm increments, as required. And yes, they're far cheaper and better than Mazda.
project.r.racing
Postby project.r.racing » Thu Jul 03, 2014 4:39 pm
Mazdas only come in 0.2 or 0.25 millimeter increments from memory. Heaps on Yahoo JP.
Postby Mr Morlock » Sat Aug 02, 2014 8:39 pm
So what was the outcome?
and1
Postby and1 » Sun Aug 03, 2014 1:50 am
Shim specs were completely off.
After the correct size shims were fitted, compression was there. Happy days!
Now just trying to get my 949 Racing twin disk clutch to disengage properly :twisted:
Garage thread
mr bender
Postby mr bender » Sun Aug 03, 2014 2:13 pm
have one with that^^^^
you need to make the throw smaller so it does not disengage then reengage.
I used a stop which screwed onto the middle of the clutch pedal arm, which hit the firewall at the right time the clutch disengage.
Postby Mr Morlock » Sun Aug 03, 2014 7:00 pm
I think that was an interesting subject and seems to have ruled out the valve timing was a player. Excellent that its fixed.
Users browsing this forum: No registered users and 76 guests
