JDM diff type?
RS2000
JDM diff type?
Postby RS2000 » Fri Jun 13, 2014 6:26 pm
What factory diff came on a JDM '99 NB (NB8C) with a 6 speed gearbox ?
Open or viscous lsd or torsen? Ratio?
Thanks in advance
Re: JDM diff type?
Postby Regie » Fri Jun 13, 2014 8:05 pm
3.9 Torsen as a guess
Re: JDM diff type?
Postby hks_kansei » Fri Jun 13, 2014 8:41 pm
Could be anything, Japan you could option different ones.
'99s were 4.1 ratio, but I;m not sure if that applied to the 6 speed.
As for the diff type, could be open, or torsen.
If it's from an RS (which I expect it is, since it's a 6 speed) it's more likely to be an LSD since I think they were standard on the RS.
zossy1
Re: JDM diff type?
Postby zossy1 » Fri Jun 13, 2014 11:57 pm
hks_kansei wrote:Could be anything, Japan you could option different ones.
Are you sure? Dad pulled an open 4.3 out of a 99 JDM NB8C (5 speed) last week. No doubt it was factory installed.
I know the ADM was 4.1 but I suspect the car we have was representative of all JDM 5 speed 99-00 NB8Cs.
emily_mx5
Re: JDM diff type?
Postby emily_mx5 » Sat Jun 14, 2014 9:02 am
Gotta be careful with your series names, all jap NBs are called nb8c (part of the vin)
Where are we use nb8a/nb8b/nb8c to distinguish them.
So you are talking about a jdm nb8a in both cases, pretty sure the RS had a torsen diff.
timk
Re: JDM diff type?
Postby timk » Sat Jun 14, 2014 10:33 pm
I think all 6 speed NB JDM MX-5s have TorSens.
spikey
Re: JDM diff type?
Postby spikey » Tue Jun 17, 2014 12:05 am
The JDM NB's with 6 speeds ran the 3.9 Torsen unlike the ADM with the 3.63 open diff, I don't think any of the JDM models had an open diff, they were all sent here instead :cry:
RS2000
Re: JDM diff type?
Postby RS2000 » Tue Jun 17, 2014 9:53 pm
Thanks for all replies - seems it's most likely a 3.9 Torsen.
The car has a 'Roadster' badge - I assume that's what you mean by 'RS' ?
emily_mx5
Re: JDM diff type?
Postby emily_mx5 » Tue Jun 17, 2014 10:24 pm
No.
Roadster is the Jap name/badging.
RS was a particular model in japan, special edition with lots of goodies.
david_syd_au
Re: JDM diff type?
Postby david_syd_au » Wed Jun 18, 2014 8:39 am
A 1999 Roadster RS would also have yellow bilstein shocks, and probably ABS
2011 NC LE "Black Beauty" (ours) | 2006 NC race car "Shazza" (his) | 1998 JDM NB race car "OMG" (hers) | NC Trailer
Users browsing this forum: Google [Bot] and 74 guests
