Boot lighting
smy0003
Boot lighting
Postby smy0003 » Thu Jun 12, 2014 11:53 pm
Here's a question I asked myself today.
If the lights for the number plate are on the boot lid, then why don't they come on when the boot is open?
I only ask after looking for a bag in the boot at night, leaning forward and smashing my head on the boot lid.
Any ideas for boot lighting?
Either using the number plate lamps or otherwise?
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
Re: Boot lighting
Postby KevGoat » Fri Jun 13, 2014 12:03 am
Not on my laptop so can't find the link, but this has been done on Miata.net iirc.
Just Google and you'll find a "how to" ...
Re: Boot lighting
Postby KevGoat » Fri Jun 13, 2014 12:10 am
Here ya go. Managed to find it on my phone ;)
http://www.miata.net/garage/99LicensePlateLight.html
Re: Boot lighting
Postby KevGoat » Fri Jun 13, 2014 12:13 am
... now you've bought this up ... I should do this mod myself ....... :lol:
Re: Boot lighting
Postby fastfreddygassit » Fri Jun 13, 2014 12:55 am
KevGoat wrote:I should do this mod myself
yes you should. It's stock on the SE........
plohl
Re: Boot lighting
Postby plohl » Fri Jun 13, 2014 7:50 am
Omgpham has boot lights now.... http://omgpham.com/boot-light
plohl
smy0003
Re: Boot lighting
Postby smy0003 » Fri Jun 13, 2014 8:28 am
The OMGPham kit looks pretty neat, I like that it uses a release switch instead of trying to wire into another circuit.
Looks like $90 well spent.
Re: Boot lighting
Postby KevGoat » Fri Jun 13, 2014 12:19 pm
:mrgreen:
Re: Boot lighting
Postby Mr Morlock » Fri Jun 13, 2014 1:19 pm
does the boot get illuminated with the lid up and parkers on? A good plan - refer davemoore recently- have a small torch in the glove box or App on phone. Dave was right about the fuse box- bloody impossible to read it at night and at an angle.
Re: Boot lighting
Postby hks_kansei » Fri Jun 13, 2014 11:03 pm
Mr Morlock wrote:does the boot get illuminated with the lid up and parkers on? .
It does, surprisingly well actually.
I tend to do this when I need to unload/load the boot at night
emily_mx5
Re: Boot lighting
Postby emily_mx5 » Sat Jun 14, 2014 9:40 am
My SE lights come on when the boot is opened. And I swapped in LEDs, so it's really bright. Would be really easy to put in a switch to make normal NB's lights turn on.
Vat
Re: Boot lighting
Postby Vat » Sat Jun 14, 2014 10:32 am
plohl wrote:Omgpham has boot lights now.... http://omgpham.com/boot-light
Nice. I've been using a small magnetic/adhesive motion-sensing LED light (similar to this:http://www.infmetry.com/home-decor/lighting/motion-sensor-led-night-light) that I'd picked up for about $10 via COTD (or similar) a few months ago but it does get through batteries.
'98 Evo Gold NB8A
mmx005
Re: Boot lighting
Postby mmx005 » Mon Jun 23, 2014 11:01 pm
Sticky back led strip , active with in line fuse wired straight to the battery and the neutral hooked up to a "tamper/pin style" switch jaycar part no LE-8775. Drill a hole in the lip next to the seal wire up and a small bit of rubber etc on top to protect your paint.
Adjust and test it doesn't stay on. Done :-)
I tested it going off buy using the video recorder on my phone
smy0003
Re: Boot lighting
Postby smy0003 » Mon Jun 23, 2014 11:14 pm
Dad pulled the rear LED centre brake light from his VE, the other day because it stopped working.
The LEDs are still working but I'll be chopping/re-soldering the strip because there's no continuity across the main + and - terminals.
So somethings gone, but the LEDs are all good.
I'll combine the strip with a non latching switch.
Already have all the parts besides the switch.
Should be a good cheap project.
kalt
Re: Boot lighting
Postby kalt » Thu Jun 26, 2014 8:29 pm
How about one of these Magic Touch Motion Sensor lights? Double-sided tape the backside and stick it to the boot lid.
Removal is straightforward just rip it out.
https://www.masters.com.au/product/9000 ... ight-8-led
It's not like anyone can fit inside the boot to trigger the sensor and drain the batteries..
Owning a fast car is easier than driving a car, fast.
For sale
NB8 Factory Airbox
Users browsing this forum: No registered users and 102 guests
