Does anyone know where I can get a set of rear bump stops. I'm changing shockies and have found the rear bump stops are perished. To suit 2001 nb with stock springs. Genuine ones are nil stock in aus. Till August
Thanks
Nb bump stops
- Regie
- Vehicle: NC - V8
Re: Nb bump stops
Get some fat cat bump stops for the USA. They are much better than the standard ones
Re: Nb bump stops
on the Fat Cat. http://fatcatmotorsports.com/
Are you retaining stock suspension or changing to coilovers?
Re: Nb bump stops
Standard suspension, just fitting new shockies
Re: Nb bump stops
Superpro Falcon ea fronts
Re: Nb bump stops
So the ea falcon ones fit the back shockies?
- Charlie Brown
Re: Nb bump stops
Fat cat without a doubt.
Front and rear will set you back about $100. Will take about a week to be delivered to your door.
The improvement over my Tein bump stops was noticeable.
- KevGoat
Re: Nb bump stops
Another vote for Fatcat stops. Made a huge difference on my NA. I should have known better and taken the time to buy a new set for my NB before putting the stock suspension back in ...
Re: Nb bump stops
Tbro's Superpro Falcon EA fronts sound interesting - there's also a damper boot/bump stop combo for the basic setup:
http://www.mx5parts.co.uk/shock-absorbe ... p-358.html
Users browsing this forum: No registered users and 376 guests
