na6 oil filter
- rossburns
na6 oil filter
hi all,
probably sounds like a silly question, but is there an easy way of removing and replacing the oil filter without also removing most of the skin off my hand
Re: na6 oil filter
Remove the things digging into your hand before you attempt to remove the filter if your arm cant physically fit in the gap.
- Vehicle: ND - RF
Re: na6 oil filter
- Learner Driver
Re: na6 oil filter
I remove the front right wheel last time I change mine. Worked well for me.
- rossburns
Re: na6 oil filter
I will look at that
- MrRevhead
Re: na6 oil filter
Use the smaller Z436 oil filter.
I have large forearms and have no problems reaching and removing the oil filter on my NA6 (even with the larger Z79A - although, it is more tight).
Remember to lube the seal with some oil prior to reapplication and also don't tighten it too tight. Just enough that it is tight/'grips', then 1/4 turn more.
Re: na6 oil filter
Weirdly, I have no particular problem with this on my NA. I have thing (read wimpy) arms. The one I hate is our Subaru Forester, where it is under the block nestled amongst the exhaust manifold.
Tim
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
- KevGoat
Re: na6 oil filter
Have you tried removing the bracket under the intake manifold to the block? I found that gave me more room.
- Gladiator
Re: na6 oil filter
Kev, isn't that bracket harder to get to than the oil filter?
- KevGoat
Re: na6 oil filter
I found it quite easy, but maybe helped by my skinny arms. Short extension on the socket. I did it from the top. Just have to feel around a bit to locate to get the socket on. First time I changed the filter on my NA I wasted money on three different removal tools before resorting to the old screwdriver through the filter method ....
Re: na6 oil filter
I just go from the top with a super cheap removal tool.
Hardest part is feeding the tool in.
The bit I hate is when the oil drips down the block.
Thinking of making a drip lip to prevent this but too many other priorities to bother just yet.
Re: na6 oil filter
just purchase one of those $15 mazda oil filter removal cups if you cant wriggle your arm in
http://www.mx5mania.com.au/oemparts.php
Re: na6 oil filter
i still have 2 billet aluminum socket tools that where never picked up or paid.
they fit onto the end of the filter and you can use 1/2 drive or use 26mm hex i milled on the end...maybe someone who got one off me can give feed back?
same thing as above post but made from solid billet and polished for the same price
works good for me
pm me if you are interested...little money
works good for me
Re: na6 oil filter
tribaldrag0n wrote:I remove the front right wheel last time I change mine. Worked well for me.
Yeah, I had the car jacked up and removed it from underneath/through the wheel well without the wheel off last time.
Took time, but no injuries.
I guess this is my signature.
