Gearbox Noises
Dundy2456
Gearbox Noises
Postby Dundy2456 » Fri Jun 06, 2014 4:31 pm
Hey everyone,
To date I haven't had any issues regarding transmission. I fit a short shifter a couple of days ago and using the standard mx5 gear knob it worked fine. Changed to a 20cm bubble shifter and now when I downshift, I get a whining noise audible in the cabin. At a guess it may be the sound of the gears/sybchro/something in the gearbox being amplified due to the larger shift knob? If that's the dumbest thing you've heard let me know.. But yeah, thoughts?
Re: Gearbox Noises
Postby Regie » Fri Jun 06, 2014 4:33 pm
All the gear boots in good order??
Dundy2456
Re: Gearbox Noises
Postby Dundy2456 » Fri Jun 06, 2014 4:55 pm
Yeah, gear boots intact, no signs of wear. Turret oil is topped up too, shift collar is the correct size. Anything else I should be looking at? I've also added some foam around the upper boot to reduce some noise.
Re: Gearbox Noises
Postby manga_blue » Fri Jun 06, 2014 6:17 pm
Same thing happened to me once on another car (actually a hot little Ford Anglia, so it's stretching the definition of "car" a bit). Swapped to a wooden gear knob and it transmitted so much gear noise I gave it away after a few days.
Dundy2456
Re: Gearbox Noises
Postby Dundy2456 » Fri Jun 06, 2014 6:41 pm
Cool.. so you're suggesting just not use the gear knob if it generates too much noise?
Should probably mention that this didn't happen when I used the bubble shift knob with the OEM shifter... Did I just answer my own question?
Gladiator
Re: Gearbox Noises
Postby Gladiator » Fri Jun 06, 2014 10:30 pm
I read your other post about fitting the SSK, & something about a wider notch than normal? could it be a vibration from that being sent up the shift stick & the different knob weight amplifying the sound?
Dundy2456
Re: Gearbox Noises
Postby Dundy2456 » Fri Jun 06, 2014 10:38 pm
The noise is still there when I grip the shift knob and there's no visible/audible rattling/vibrations of the shifter unit as a whole.
An example scenario when I'd notice the whining noise would be travelling at 40km/h, downshifting from 3rd to 2nd to turn a corner.
Users browsing this forum: No registered users and 29 guests
