MONDA - the Honda Powered MX5
sailaholic
Re: MONDA - the Honda Powered MX5
Postby sailaholic » Mon Jun 02, 2014 12:55 pm
My guess is no bracing. If you read light years posts, he had all the bracing, removed it and found no loss.
TTT
Postby TTT » Mon Jun 02, 2014 3:32 pm
Love this idea.
Look forward to updates of it running and costing etc (if you plan on doing so)
oztrackdays
Suspension Upgrade
Postby oztrackdays » Mon Jun 02, 2014 7:29 pm
Have decided to try a made to order set of TrakSPAX coilovers. They are aluminium might
save a few grams of weight over OEM but I had some Tein SS on the car at present so probably little in weight.
They cleared customs today and will also doing the full set of car bushes at the same time,
so won't be on the car for it's first shakedown run but should be fitted up next week.
sailaholic
Postby sailaholic » Mon Jun 02, 2014 8:01 pm
Make sure your suspension pivots easily after the new bushes.
oztrackdays
Electronics Upgrades
Postby oztrackdays » Mon Jun 02, 2014 11:26 pm
Hondata Traction Control for "cheating", car isn't really eligible for anything anyway and
next time I end up at Phillip Island or Bathurst again and it's pissing down rain I won't
feel so bad about the cop out :idea: http://hondata.com/traction_control.html
it can be setup to only trigger during cornering even.
Will reuse the Motec Dash for logging and dashboard guage duties.
There's only 1 real luxury I really need, that is Cruise Control, it's a 9 hour drive
to Phillip Island and I don't like talking with those unfunny blue clowns.
http://www.ebay.com/itm/Rostra-250-1223-Universal-Cruise-Control-Kit-with-250-3742-Lighted-Handle-Stalk-/261094381290?ssPageName=ADME:L:OU:AU:3160
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Jun 06, 2014 10:56 am
i hear this thing has breathed life?
Postby NitroDann » Fri Jun 06, 2014 11:30 am
Last night at 1130.
Junkee
Postby Junkee » Fri Jun 06, 2014 7:09 pm
What dry sump kit does it run and roughly how much does it cost?
Cheers ;)
Liam, 25, Brisbane
My Instagram
Postby NitroDann » Fri Jun 06, 2014 8:31 pm
sailaholic wrote:My guess is no bracing. If you read light years posts, he had all the bracing, removed it and found no loss.
All of the factory bracing fits and currently is in use.
Postby NitroDann » Fri Jun 06, 2014 8:39 pm
Here we go. As of right this instant. Thats a pretty good effort.
Dweezle
Postby Dweezle » Fri Jun 06, 2014 8:47 pm
Unreal!!!!
Can not wait to see some lap times.
I wish this didn't cost 15+grand.
How come the NB only had 63kw??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
oztrackdays
Postby oztrackdays » Fri Jun 06, 2014 8:50 pm
Indeed thanks for the exhaust Dann I am told it's a good looking exhaust.
Postby NitroDann » Fri Jun 06, 2014 9:05 pm
Yeah it came up nice, I guesstimated the K24 header flange location from photos and memory and got it spot on, the crossover to the other side of the chassis is pretty clever when you see it, and it even fits the OEM front brace without modification, not even washers.
Benny told me last night that its really sensible on idle but really opens up on VTEC. It has a resonator and a really big muffler and we stuck with 2.5" not 3" but 230whp n/a is a lot of flow to keepp quiet :P
oztrackdays
Postby oztrackdays » Fri Jun 06, 2014 9:30 pm
It's going to Marulan on the 16th if it's quiet enough for there then perfect otherwise may need a special crippled resonator for the noise sensitive days.
Apu
Postby Apu » Fri Jun 06, 2014 10:09 pm
Dweezle wrote:Unreal!!!!
When you think about it, it's not bad! This is 175kW with the potential for more, plus the reliability of NA...looking more and more compelling.
Users browsing this forum: Bing [Bot] and 187 guests
