FIRST Friday of the month Mt. Nebo/Glorious run
Queensland Events
Moderators: timk, Andrew, miata, AJ
Gladiator
Re: FIRST Friday of the month Mt. Nebo/Glorious run
Postby Gladiator » Thu Jun 05, 2014 6:13 am
Nope. Hole in my exhaust.
phoe
Postby phoe » Thu Jun 05, 2014 9:00 am
Just one is fine, can you fix any extras by Friday night?
Phoe
jono
Postby jono » Fri Jun 06, 2014 1:10 am
New owner here, might be able to make it Fri night depending on details. I'll never keep up without a turbo though I suspect!
mattyredlocks
Postby mattyredlocks » Fri Jun 06, 2014 7:10 am
jono wrote:New owner here, might be able to make it Fri night depending on details. I'll never keep up without a turbo though I suspect!
Hope you can make it!
You'll keep up fine, no turbo on mine either ;)
But the limit is 80 for the most part up there anyway, so I wouldn't worry about being left behind.
Because reasons.
MattyRedlocks' MX-5: Moxxi the NB (Currently running, and properly for once!)
Steampunk
Postby Steampunk » Fri Jun 06, 2014 11:24 am
I need a lift from South Brisbane...
... Then be dropped off home :mrgreen:
phoe
Postby phoe » Fri Jun 06, 2014 3:00 pm
Steampunk wrote:I need a lift from South Brisbane...
I already have a counterweight.
PM -> Jono.
Phoe
Gladiator
Postby Gladiator » Fri Jun 06, 2014 5:14 pm
phoe wrote:Just one is fine, can you fix any extras by Friday night?
No mate. I'm at work. Can't get it fixed until Tuesday at the earliest. :(
jono
Postby jono » Fri Jun 06, 2014 7:28 pm
I'm in tonight :D
slug_dub
Postby slug_dub » Mon Jun 30, 2014 7:49 pm
My car is on the road again (yay!) so this Friday I am in for my first drive this whole year :-D
Might also have a ring in from Rocklea.
sailaholic
Postby sailaholic » Mon Jun 30, 2014 8:20 pm
Wow, should have joined Shane and I at the rocklea suspension proving circuit last night. We were back to backing ohlins vs mca red.
slug_dub
Postby slug_dub » Mon Jun 30, 2014 9:29 pm
Bah did not know! Results please!!
sailaholic
Postby sailaholic » Mon Jun 30, 2014 9:58 pm
Well we both drove both cars ... I thought maybe the ohlins had the edge, Shane thought maybe it was the mca.
So I'd say sufficient detail to say mca red is definitely a competitor to ohlins but not enough testing to get a winner.
I think Shane said mca has a better range of travel but I could be wrong.
D.A.M
Postby D.A.M » Tue Jul 01, 2014 1:21 am
ill join if i can ride passenger with someone? :D
White 1993 NA6
viewtopic.php?f=57&t=57652
Lakeside: 1:09
ManiacLachy
Postby ManiacLachy » Tue Jul 01, 2014 8:53 am
I would like to make one of these, but unfortunately won't be this month.
To clarify, you guys meet on Milton Road at 730/8 for a coffee then do the run?
sailaholic
Postby sailaholic » Tue Jul 01, 2014 9:02 am
No run is before the coffee. I forget the meeting time it's been too long. Someone will pm you the details.
Remember the mountain zero campaign is still running so expect police attention and you can only be pleasantly surprised rather then unpleasantly.
http://mypolice.qld.gov.au/brisbanewest ... -accident/
Return to “Queensland”
