Dan's NC track toy
Re: Dan's NC track toy
Postby Regie » Fri May 30, 2014 2:42 pm
I'll have a pbox down at the track day on Sunday, will be good to compare data. I'm hovering around the 1.12 mark
Postby Magpie » Fri May 30, 2014 3:49 pm
Dan also have a look at the max speed down the straight and how long it takes to accelerate to this speed. For me at least, I have the same corner speeds as much faster cars, however lack the acceleration out of the corners.
Can you also look at when the others are braking as this will also help explain some of the 'slowness'.
If it makes you feel less nerdy I just did a whole pile of acceleration, force, torque, mass, time calculations in my build thread regarding gearbox/final drive ratios. The conclusion was it is much better if the driver and the car loose the weight than swaping a final drive ratio.
Dan
Postby Dan » Fri May 30, 2014 6:53 pm
Regie - sound good, I'll bring my laptop, I'd love to overlay our laps :)
Magpie - That's a great point, I am definitely thinking of exit speeds and understand corner speeds don't tell the whole story, it needs a full set of data to compare them though.
Guran is a good example of someone that has incredible corner speeds for his setup but when I watch one of his videos I can see why he has the cornering speeds he does.
Nevyn72
Postby Nevyn72 » Fri May 30, 2014 6:55 pm
Dan wrote:Regie - sound good.......... I'd love to overlay our laps :)
Are you sure you don't want to re-phrase that?!!!! :shock:
Postby Magpie » Fri May 30, 2014 6:57 pm
I'll try and get down your way this year and we can compare nerd notes :)
Plus I can produce a VBO file for you.
Dan
Postby Dan » Fri May 30, 2014 6:58 pm
Haha, should of used the quote tool.
Overlay our lap times in circuit tools on my laptop.
Dan
Magpie wrote:I'll try and get down your way this year and we can compare nerd notes :)
Sounds good :)
Postby Regie » Fri May 30, 2014 8:26 pm
Haha yep sweet.
Looking at your video I don't hit 2nd gear at all around the track, it looks like you hit 2nd around the fish hook and turn 10. I'm also grabbing 4th after t2 and holding 4th thought t3 then back to 3rd for the t4 right hander. Then again I have a 4.1 rear end which will make a bit of difference.
Dan
Postby Dan » Fri May 30, 2014 9:27 pm
Haha yep sweet.
Yeh, I think it is probably the FGR. There was actually some good talk from Charlie Brown and others earlier in this thread about gear selection.
If I can get some more corner speed around T2 I can see the rev limiter being hit by T3 but I'm still not sure if I'd shift or just leave it on the limiter for a second or so.
Postby Regie » Fri May 30, 2014 10:13 pm
Just read CB's post regarding gear changes. I'm pretty much the same as him. That was a old post and I would have had my 3.7 fgr in then.
I haven't touched 2nd gear even with the taller fgr. I might do some experimenting....let's see if the rev limiter is there :shock: haha.
Last SOTS day I was grabbing 5th down the straight
Come and find us on Sunday, will be good to meet you :D
Dan
Postby Dan » Fri May 30, 2014 10:45 pm
Regie wrote:Just read CB's post regarding gear changes. I'm pretty much the same as him. That was a old post and I would have had my 3.7 fgr in then.
Yeh, always good to try things, don't downshift too low and over rev though :o
I'll keep an eye out for you on Sunday, I'm in car #1 (Black with brown top).
Postby Regie » Sat May 31, 2014 5:43 pm
#1!! I'm 28. Silver Nc with mazdaspeed kit. Looking forward to it!
cwto24
Postby cwto24 » Sun Jun 01, 2014 10:50 pm
Dan! Good meeting you today!
I was the guy in the Grey NC in your class!
Fun times today and some offroading!
Regie wrote:spending my money again Trevor :D
Dan
Postby Dan » Mon Jun 02, 2014 9:05 am
Was cool meeting you as well. Was a wet day but a ton of fun! My girlfriend got some pictures on my camera from the hill of our group, hopefully I've got one of you :)
Luckily I didn't go off myself but I ended up having a bit of a slide just after T5 after coming out too wide onto the ripple strip which was like hitting ice.
Managed a 1:16.00 in the end on official timing, not too upset about that since I was being pretty cautious about the circuit being partially damp.
Thanks everyone for a fun day, I'll be at circuit club next Monday if anyone's around.
oztrackdays
Reference Lap VBO File 1.08.55 Wakefield
Postby oztrackdays » Mon Jun 02, 2014 7:37 pm
This is in the NA8 Racecar with Daniel driving tyres were pretty old.
7th-July-2013 1-08-55.zip
