15 x8 + 20 offset question
ralt
Postby ralt » Wed May 21, 2014 12:58 pm
Hi.
I have the opportunity to buy wheels as above.
The question is will they fit without having to roll the guards and will a 195 50 tyre fit?. If not what do you recommend.
ralt
Re: 15 x8 + 20 offset question
Postby ralt » Wed May 21, 2014 1:29 pm
Hi again.
Forgot to advise the model: na
zossy1
Postby zossy1 » Wed May 21, 2014 1:34 pm
You will need to roll the guards but they will fit fine.
narita
Postby narita » Wed May 21, 2014 1:59 pm
its a very common size.
if you google search those specs with "miata mx5" you should fine what your looking for,
otherwise you can also use willtheyfit.com
OR
you can do some old fashioned brain work and measure it.
WINTON PB - 1:57.4000
Dundy2456
Postby Dundy2456 » Wed May 21, 2014 4:33 pm
I have this size and offset. No guard work at all. No scrub, wheels fit fine.
zossy1
Postby zossy1 » Wed May 21, 2014 6:27 pm
Dundy2456 wrote:I have this size and offset. No guard work at all. No scrub, wheels fit fine.
A good sized pothole on heavy lock and you will crease your guard when the tread catches on the lip and unrolls it. Ask me how I know.
Postby hks_kansei » Wed May 21, 2014 6:50 pm
I had 15x8+25 on my NB, with 205/50/15 and it clipped the rear guards slightly.
narita
Postby narita » Wed May 21, 2014 6:52 pm
hks_kansei wrote:I had 15x8+25 on my NB, with 205/50/15 and it clipped the rear guards slightly.
8a or 8b?
project.r.racing
Postby project.r.racing » Wed May 21, 2014 9:14 pm
8a or 8b?
he has a 8a. but does it matter? same body aren't they?
beavis
Postby beavis » Wed May 21, 2014 9:18 pm
8A and 8B are the same.
Rolling the guard lip is easy anyway.
Guard clearance is also gonna depend on ride height.
zossy1
Postby zossy1 » Wed May 21, 2014 9:59 pm
beavis wrote:8A and 8B are the same.
True, but who runs 15x8 +20 at standard ride height? :) Even at stock height, a good pothole with some decent steering lock and unrolled guards is asking for trouble.
Why not just roll the guards? It's not hard and if done right it won't even chip the paint.
Dundy2456
Postby Dundy2456 » Wed May 21, 2014 11:10 pm
How do you know? haha (kidding). A good sized pothole on heavy lock for any car (that is as roadster-y as the mx5) is bad news :p I do my best to avoid them!
project.r.racing
Postby project.r.racing » Fri May 23, 2014 9:59 am
jeez how fast you going at full lock when hitting a pothole to cause damage?
i cannot do more than 15kph at full lock.
Postby manga_blue » Fri May 23, 2014 10:37 am
You can be going much faster when it's opposite lock. :beer:
narita
Postby narita » Fri May 23, 2014 2:43 pm
project.r.racing wrote:
8a or 8b?
i was more so wondering if he had 15's on a 8b since the brakes are bigger.
Users browsing this forum: No registered users and 344 guests
