NA6 Electric windows stopped working.
StanTheMan
Postby StanTheMan » Sun May 18, 2014 7:56 am
electric windows are not working
Ive checked fuses. under dash & engine bay. several times....unless ive missed one.
its unlikely the ignition barrel. when thats faulty. the wipers & wiper water dont work either. both those work.
switch?
any Idears where to start looking
if anyone knows which fuse....I'll check it again.
Re: NA6 Electric windows stopped working.
Postby Magpie » Sun May 18, 2014 9:06 am
Is the window motor working?
It could be the switch contacts. Do you have a multimeter?
StanTheMan
Postby StanTheMan » Sun May 18, 2014 9:10 am
I don't have a multimeter. Wouln't have a clue how to use one either. :roll: :oops:
neither window is working. So that kind of makes me think its either a fuse or a completely buggered switch.
the switch itself it is not possible to remove wiring without cutting the wire....so cleaning contacts....perhaps not possible?
StanTheMan
Postby StanTheMan » Sun May 18, 2014 9:20 am
So I can't clean the contacts.
But I guess I'll take the switch apart & clean internally?
StanTheMan
Postby StanTheMan » Sun May 18, 2014 9:31 am
Thank you to a very kind person who sent me the fuse diagram via PM
To that person.
Thank you so much. I missed that fuse a few times :oops:
Windows are working.
Thanks all.
one happy camper
Postby Magpie » Sun May 18, 2014 9:44 am
By the way you can clean the contacts. Pop the switch apart. This is how you can rectify slow windows.
StanTheMan
Postby StanTheMan » Sun May 18, 2014 10:47 am
Ok cheers
ralt
Postby ralt » Mon May 19, 2014 3:38 pm
Hi.
If you take the switch apart do it with the switch in a bag to contain the contacts as they are rather small.
