5v Battery packs
5v Battery packs
Postby Okibi » Thu May 15, 2014 2:22 am
I've been pondering running a permanent camera or two in my people mover.
An idea I had was to buy an [url="http://www.ebay.com.au/itm/Anker-Astro-Pro2-20000mAh-External-Battery-Pack-Laptop-Smartphone-/191093626475?pt=US_Cell_Phone_PDA_Batteries&hash=item2c7e11566b&_uhb=1"]external battery pack designed for usb devices like this[/url], and wire it in to only charge when the ignition is on.
That way the camera will only drain its own battery and not the cars and the camera would still record when the car's battery has been disconnected.
Don't want to do a full on dual battery system.
Don't care if the external battery pack is bigger but needs to be small enough to fit under the dash or a seat etc.
I want it to work automatically, not have to press it on/off etc, this might be the biggest hurdle as most of these seem to have a power button.
I guess i'd need to be driving around long enough for this battery to recharge.
I know a lot of camera have their own built in batteries but I want a longer lasting solution.
I know that there are solutions for camp fridges that would last for ages powering cameras but those all seem too bulky.
Keen to know if anyone else is doing something similar and what solutions they've come up with.
Re: 5v Battery packs
Postby hks_kansei » Thu May 15, 2014 6:27 pm
How much power draw does the camera have?
How often would you drive the car? (I'm assuming daily?)
I'd expect it to be pretty low draw, since the cameras can be charged from a USB normally. Which is 5v and low amp.
You can usually leave on parking lamps all night without issue, and they draw 12v and about 5 amps (5wx2 front, and 20wx2 taillights)
If you're concerned though, I'd probably look into one of the solar trickle chargers.
I think there are also devices available that will allow power to be drawn to a certain point, then cut it (ie: before the battery loses enough power to not crank)
Snowmotion
Postby Snowmotion » Thu May 15, 2014 10:12 pm
What sort of people mover is it?
I have installed a dual battery on my VW Transporter and then added USB sockets for the families devices.
Postby Okibi » Thu May 15, 2014 11:14 pm
hks_kansei wrote:...I think there are also devices available that will allow power to be drawn to a certain point, then cut it (ie: before the battery loses enough power to not crank)
Yeah i'd ponder one of these to make use the usb battery got enough charge.
Snowmotion wrote:What sort of people mover is it? ...
WRX
Snowmotion
Postby Snowmotion » Thu May 15, 2014 11:37 pm
Postby Okibi » Fri May 16, 2014 12:02 am
Looks like they left it out in the sun :shock:
Users browsing this forum: No registered users and 106 guests
