bit more power
rossburns
bit more power
Postby rossburns » Fri May 09, 2014 3:55 pm
hi all,
what would be the best way of giving my nA mx5 a bit more power, was thinking about the 125kw sort of figure
Re: bit more power
Postby bruce » Fri May 09, 2014 4:14 pm
This is the most discussed topic in the forum. There are 2 recent topics asking the same question. I would guesstimate there are a few thousand pages discussing this, covering the span of the last 20 years.
Top right of the page is the 'Search' function.
Re: bit more power
Postby NitroDann » Fri May 09, 2014 4:52 pm
Ill give you a hint :)
Its starts with 'Z'.
And ends with UTUTUTUTUTUTTTUUUUUUUUTUUUUUU!!
Like every car in this photo.
bootz
Re: bit more power
Postby bootz » Fri May 09, 2014 5:15 pm
Dann you're preaching to the choir. Again.
Apu
Re: bit more power
Postby Apu » Fri May 09, 2014 5:19 pm
rossburns wrote:hi all,
For what you'd spend to get to 125kw...you'd probably get 140rwkw really easily with a turbo.
If you search and look at all the kits Dann has built - they really are flat power "curves", just a straight line pointing about 40-45 degrees, no lag.
And for all others considering a turbo build, looking for a cheap turbo...forget the S15 turbo route unless you REALLY know the condition of the turbo.
You can buy a used Volvo TD04 cheap, and you can be quite sure it hasn't had the living daylights thrashed out of it.
Re: bit more power
Postby Magpie » Fri May 09, 2014 5:59 pm
Do you want FI or NA 125 kw?
cookie
Re: bit more power
Postby cookie » Fri May 09, 2014 6:04 pm
hopefully NA ;)
Re: bit more power
Postby NitroDann » Fri May 09, 2014 6:58 pm
NOS.
cookie
Re: bit more power
Postby cookie » Fri May 09, 2014 8:07 pm
Certainly a cost effective way that's for sure.
davekmoore
Re: bit more power
Postby davekmoore » Sun May 11, 2014 5:27 pm
If you go the turbo direction I have the world's most cost-effective intercooler for sale. From an SE, complete with various pipes. I don't understand what the pipes are or whether they'd be any use but the whole lot is $20 plus postage.
Also an SE ECU becoming available in the near future.
Also an SE exhaust manifold to suit an IHI turbo.
Also a dismantled IHI turbo needing an overhaul.
Re: bit more power
Postby Lokiel » Sun May 11, 2014 6:16 pm
Read this: http://www.solomiata.com/CheapHP.html
- you'll come to the conclusion that Dann is not just preaching on a soapbox.
Apu
Re: bit more power
Postby Apu » Sun May 11, 2014 10:30 pm
Talk to NitroDann about how to piece together a budget turbo build that will get you that 125kw.
The silver NB in the photo is mine. Mania have just finished the tune and I am thoroughly enjoying the car.
How much am I enjoying the car? To put things in perspective, I just discovered today that the battery on my DC2 Integra Type R has gone flat and I only took the Lotus Elise out for a drive yesterday as the fuel has been sitting in the tank for about 3 weeks.
oztrackdays
for NA 125+ rwkw
Postby oztrackdays » Sun May 11, 2014 11:37 pm
It starts with $$$ and then you throw some more $$$$ at it and then you get there in the end.
Can it be done for less than $10k will leave that to the internet experts, but it cost me a little more than that.
davekmoore
Re: bit more power
Postby davekmoore » Mon May 12, 2014 8:23 am
There were recently a couple of kits or part kits for sale. Worth a search. sprx3 was one of the posters.
mazmad
Re: bit more power
Postby mazmad » Mon May 12, 2014 1:44 pm
You are after a 50% increase which is more than a bit.
CHEAP FAST REALIABLE You can choose two.
