Got home...just
Re: Got home...just
Postby Mr Morlock » Thu May 08, 2014 7:20 pm
manga delivers sage advice on these things. IAs suggested borrow a coil packs from a mate- do one at a time- test drive etc that should assist in ruling that out. You can also get coil packs tested on a bench and repaired - however I cannot say for sure whether the test or the repairs are 100%. I think Manga is spot on that the old cars were easier to fix but they were far less reliable .
JBT
Re: Got home...just
Postby JBT » Thu May 08, 2014 10:01 pm
A set of plug leads and plugs won't send you broke and you'll find that the car tends to go through these as it works on a wasted spark system. If they don't fix the problem, you'll have a known good spare set.
plohl
Re: Got home...just
Postby plohl » Thu May 08, 2014 10:35 pm
I have a set of leads lying around if you want to test them out. Selling them cheap too
plohl
Odd
Re: Got home...just
Postby Odd » Fri May 09, 2014 12:58 pm
Thanks for advise!!
I got back last night….bought New spark plugs and leads this morning and change them myself
all sorted!!!….….;)
At least I've found that it's a 4 pin coil pack….manufacture Feb '95
and I've now got a led light setup to test for engine faults!
You can't demand respect....you have to earn it
NA8 for Fun, CX5 for carrying crap...;)
Re: Got home...just
Postby manga_blue » Fri May 09, 2014 1:49 pm
Nice work.
taminga16
Re: Got home...just
Postby taminga16 » Fri May 09, 2014 1:54 pm
Well done.
Re: Got home...just
Postby bruce » Fri May 09, 2014 4:16 pm
bruce wrote:Plug leads!
I've known the answer for nearly 20 years.....
Odd
Re: Got home...just
Postby Odd » Fri May 09, 2014 5:26 pm
Thanks Bruce
You were right…. :D
Although….it may have been the plugs….I think they were originals!!!
