NA6 Rust
Re: NA6 Rust
Postby Regie » Sun May 04, 2014 7:44 am
Rust will prolly be found in the most obvious places. Under the front guards, behind the front wheels. The parcel shelf behind the seats is also a common area.
Possibly the lower windscreen surround also, that's if it's had a dodgey screen put in
Re: NA6 Rust
Postby hks_kansei » Sun May 04, 2014 9:35 am
Main points I'd be looking at:
Bottom of front guards (dirt/leaves collect here)
Around the boot seals.
Bottom of windscreen frame (where it joins to the main car)
Top of windscreen frame, near the latches (drain gets clogged, water collects)
Those are the main points I've seen rust of them, the most common I've seen is the windscreen area. It's just a combination of design, and lack of cleaning (drains) that causes water to collect and rust those areas.
Re: NA6 Rust
Postby hks_kansei » Sun May 04, 2014 9:08 pm
You can slow it down with rust converter if it;s only light, but if it's heavier you'll need it removed.
Removal is usually a matter of cutting the rusted section out and welding in a new patch.
Prevention is to try and keep rust prone areas clear of standing water/dirt, and to every so often give them a spray with fish oil.
Re: NA6 Rust
Postby Regie » Mon May 05, 2014 8:58 am
Sounds like the car doesn't have a sealed battery.
sailaholic
Re: NA6 Rust
Postby sailaholic » Fri May 23, 2014 12:22 am
Don't try and colour paint galvanised steel...doesn't work well.
trader
Re: NA6 Rust
Postby trader » Wed Nov 19, 2014 10:11 am
Surprised to see all this rust on an MX. Maybe its been pranged in the past?
NB SE, NA 1.8.
ralt
Re: NA6 Rust
Postby ralt » Wed Nov 19, 2014 10:20 am
Hi,
From the photos your car has been repainted therefore you may be in for some more nasty surprises.
Dehamsta
Re: NA6 Rust
Postby Dehamsta » Wed Nov 19, 2014 11:13 am
Sell it and buy another without rust. When I bought my na my main requirement was that it was rust free which is more important than paint condition.
Re: NA6 Rust
Postby Mr Morlock » Wed Nov 19, 2014 1:28 pm
It does not look very good. What could be done is show it to a body shop and get an assessment of how extensive it is and cost to repair. If its thousands to weld in panels etc in structural areas it might not be a proposition as a longer term. The car may have been in an exposed sea frontage area which takes a heavy toll.
emily_mx5
Re: NA6 Rust
Postby emily_mx5 » Wed Nov 19, 2014 2:06 pm
I'm not sure who would buy it, that rust is very evident. There will most likely be more rusted areas too.
Re: NA6 Rust
Postby bruce » Wed Nov 19, 2014 4:02 pm
3k quote is a bit much. Get another quote.
