How to clean the inside of a transmission
kalt
Re: How to clean the inside of a transmission
Postby kalt » Thu May 01, 2014 11:01 am
tescoking wrote:Not really sure about that as the problem only seems to happen on 2nd gear. For example this issue happen when I try to shift gear from 3 to 2, and the shifter doesn't get in, I need to press the clutch again to pull into 2nd gear, or from 1st gear to 2nd at traffic light.
[/quote]
Does it happen only when the box is cold or irrespective of temps - just thinking that change of season and ambient temps drop so initial shift feels clunky when cold.
When you mentioned events, was there a significant difference in feel from when you first bought the car, to the gearbox pin issue to now?
Owning a fast car is easier than driving a car, fast.
For sale
NB8 Factory Airbox
tescoking
Postby tescoking » Thu May 01, 2014 1:05 pm
When you mentioned events, was there a significant difference in feel from when you first bought the car, to the gearbox pin issue to now?[/quote]
The problem is always here, since I bought the car till now. I did think about it is the oil temp so the gear is not smooth. But this sometimes happen during the race, but less offen than normal driving.
Maybe should try to change the sleeve first?
My 5
kalt
Postby kalt » Thu May 01, 2014 1:19 pm
Ah, if it has been like that since new then it could have been an opportune time to get it inspected when the wrong bolt came out.
I've had trouble getting from 1st to 2nd but it's only during cold cold mornings recently, the box oil is due for a change soon.
For sale
NB8 Factory Airbox
tescoking
Postby tescoking » Thu May 01, 2014 6:59 pm
kalt wrote:Ah, if it has been like that since new then it could have been an opportune time to get it inspected when the wrong bolt came out.
Oh, getting stuck in the morning almost happen everyday. Just not sure why it still happen after the car is warm.
My 5
ralt
Postby ralt » Thu May 01, 2014 7:55 pm
HI.
Best way to "clean the inside of transmission " and shifting issues is to dismantle the box by somebody who knows what they are doing correct any problems then you will be a happy. Amen.
Pamex
Postby Pamex » Thu May 01, 2014 8:39 pm
Get some prices on a rebuild, but you may end up going with a second hand one.
Work's charge rate for one of my fully re-conditioned boxes, installed, is $5,000 roughly. Usually with whatever good second hand parts I can find. But we're a specialist, and some of the parts are getting scarce. Not sure on what other people charge.
Obviously I don't see any of that money, but I'm just glad that no-one else at work has done any, or wants to attempt gearboxes. It leaves me time devoted to my one true love. :mrgreen: :mrgreen: :mrgreen:
tescoking
Postby tescoking » Thu May 01, 2014 9:06 pm
Pamex wrote:Get some prices on a rebuild, but you may end up going with a second hand one.
pretty sure in Perth will be more expensive, I might consider a 2nd hand gearbox now...But what if I bought a bad condition gearbox again? =.=
My 5
Pamex
Postby Pamex » Thu May 01, 2014 9:11 pm
Ask around. It can't hurt to get some rough prices. Remember to get quoted on install unless you plan on installing it yourself. Labour is a killer, and there is a LOT of labour in doing a gearbox, or a remove and refit.
tescoking
Postby tescoking » Thu May 01, 2014 9:13 pm
Pamex wrote:Ask around. It can't hurt to get some rough prices. Remember to get quoted on install unless you plan on installing it yourself. Labour is a killer, and there is a LOT of labour in doing a gearbox, or a remove and refit.
I asked one place and just to remove and inspect cost $500.
My 5
sailaholic
Postby sailaholic » Thu May 01, 2014 9:18 pm
Tesco pamex is building mx5 gear boxes but English sports cars so parts might actually be more expensive.
tescoking
Postby tescoking » Thu May 01, 2014 9:56 pm
sailaholic wrote:Tesco pamex is building mx5 gear boxes but English sports cars so parts might actually be more expensive.
Ummmm, then I will ask them again to see what will be the high cost for rebuild my gearbox.
My 5
project.r.racing
Postby project.r.racing » Fri May 02, 2014 8:33 am
$2.5K - like i said before. good way to blow another $2.5K.
Go buy a second hand box for $800-$1000 and install.
tescoking
Postby tescoking » Fri May 02, 2014 2:49 pm
project.r.racing wrote:$2.5K - like i said before. good way to blow another $2.5K.
6spd gearbox from Mx5plus cost $1650 and not including shipping, installation.
My 5
bootz
Postby bootz » Fri May 02, 2014 2:53 pm
Just junk the six speed and put a nice 5 speed in; You will appreciate the difference. :D
tescoking
Postby tescoking » Fri May 02, 2014 4:19 pm
bootz wrote:Just junk the six speed and put a nice 5 speed in; You will appreciate the difference. :D
I just love 6spd so much XD
My 5
