Okibi's SE
Re: Okibi's SE
Postby Lokiel » Mon Apr 28, 2014 10:42 pm
You're a bit brighter than me on the clearcoat then, I didn't do it on mine and wished I did since I now have to redo it.
I've tried sanding it back a bit and respraying it but anodised red just looks patchy so needs to be sanded right back to bare metal to get the pain even :(
Re: Okibi's SE
Postby Okibi » Mon Apr 28, 2014 11:50 pm
Can you use a paint stripper?
Nevyn72
Re: Okibi's SE
Postby Nevyn72 » Tue Apr 29, 2014 9:03 am
Okibi wrote:.......for when I can be bothered installing my FM twincooler.
Twin cooler? Is that one of those seriously cool combined radiator/oil cooler jobbies? :mrgreen:
Re: Okibi's SE
Postby Okibi » Tue Apr 29, 2014 10:18 am
Yup was in my red NB
Re: Okibi's SE
Postby Lokiel » Tue Apr 29, 2014 1:45 pm
That is a gloriously simple solution to fitting an oil cooler into an NA/NB - wish I'd seen it before fitting mine in the driver-side wheel well.
Since you haven't fitted it, if it doesn't have one already, consider adding a drain plug to the bottom of the oil cooler section so that you can properly flush the oil when doing oil changes. One of the problems with many oil cooler solutions is that after an oil change, you still end up with old oil in the system that was sitting in the oil cooler.
Re: Okibi's SE
Postby Magpie » Tue Apr 29, 2014 1:57 pm
I have one of those PWR radiator/oil combos as well, worth the money.
Re: Okibi's SE
Postby Lokiel » Tue Apr 29, 2014 2:15 pm
I just checked out this radiator/oil cooler combo in Magpie's thread.
Okibi wrote:Its the Flyin Miata "twincooler", when I got mine it was cheaper shipped from the US than wholesale price in Oz. :roll:
Also it doesn't have an oil drain hole at the bottom, if you buy one consider getting one welded in before you put it in the car.
I see Okibi that you've already considered my previous suggestion :P
Re: Okibi's SE
Postby Magpie » Tue Apr 29, 2014 2:18 pm
I was looking to see if mine included one as it was an Australian delivered version, it appears not.
Re: Okibi's SE
Postby Okibi » Tue Apr 29, 2014 8:53 pm
Lokiel wrote:...I see Okibi that you've already considered my previous suggestion :P
Perhaps we were separated at birth? :lol:
track_addict
Re: Okibi's SE
Postby track_addict » Wed Apr 30, 2014 10:45 pm
Oh man I want one of those. I've spent alot of time thinking where the best spot for an oil cooler is, I now have an answer. Now to find out who else makes them as it seems FM doesn't make them anymore :(.
89' Roadster - Sold
'04 SE - Sunlight Silver.
Re: Okibi's SE
Postby Lokiel » Wed Apr 30, 2014 10:59 pm
See http://www.pwr.com.au/portfolio/mazda-car-radiators - Part No: PWR5119 – MX5 with Attached Oil Cooler ’90-’97
They're an Aussie company but unfortunately like most good Aussie products, it's cheaper to import them back to Australia from O/S.
ie. FM no longer sell them but you can order them direct from PWR Performance Products at extorted-Aussie prices.
track_addict
Re: Okibi's SE
Postby track_addict » Wed Apr 30, 2014 11:07 pm
Thanks for that Lokiel. Have emailed to see just how much it is. If it is as bad as you say, its no wonder people buy so much stuff from overseas/the internet. Yet local business won't help themselves.
89' Roadster - Sold
sailaholic
Re: Okibi's SE
Postby sailaholic » Thu May 01, 2014 6:28 am
Beware of PWR. They can do good work, and charge like it but unless your a high end race team...
Last I checked the combo was about a grand. Magpie bought one and mx5 plus had all sorts of trouble fitting it because they made it the wrong size. Their drawing was wrong to make it fit and the rad didn't even match the drawing!
Response from PWR? We make f1 gear, we're never wrong, must be you".
emily_mx5
Re: Okibi's SE
Postby emily_mx5 » Thu May 01, 2014 8:55 am
Had a chat to them yesterday.
NB part no is pwr5118, retails for $1,265.
Core is 55mm, but total depth is 67mm which sounds huge and would need slim fans to fit with SEs IC piping, I still don't know whether it would fit.
bootz
Re: Okibi's SE
Postby bootz » Thu May 01, 2014 3:44 pm
Almost $1300 for rad and cooler :frown: :frown: :frown: :frown:
Guess I have to wait for the china copy.
