Yellow Speed brakes fit under Enkei Compe 15x8 25 offset?
- davekmoore
As the title says, need guidance please from someone who has done this. Looking at the 286 or 304mm Yellow Speed brakes. Wanting to avoid spacers if possible.
Re: Yellow Speed brakes fit under Enkei Compe 15x8 25 offset
I don't have YellowSpeed brakes but Works Engineering ones on my Integra, with 302mm rotors. There is a little bit of room under the 16" wheels so I would say the 304mm YS won't fit under 15s.
- Vehicle: Non MX-5
the 304s wont fit. the 286s are for 15s.
if you ask the supplier, they can get a pdf templet for printing in A4, then cut it out and test on wheel. i did it for one of my wheels.
- davekmoore
project.r.racing wrote:the 304s wont fit. the 286s are for 15s.
YS are not replying to emails.
Try their stockist... Mania
- Vehicle: Non MX-5
^this^sailaholic wrote:Try their stockist... Mania
I originally contacted YSR and the replied saying to do as advised. I think it was wholesale suspension. But Mania will do the same job.
- zossy1
Mania probably won't know either. The Enkei Compe in 15x8 +25mm is a rare wheel in Australia, and the YS brakes aren't all that common either so my guess is you will be the first to run this combo.
You may have some luck checking the CR.net or other big US forums for indicative info on how much clearance these wheels have - if they clear Goodwin's kit of the TSE 11.75" kit, then chances are they will clear the YS 286mm kit as well.
Users browsing this forum: No registered users and 297 guests
