Shims lifting on angle due to cam regrind
Supposedly my car is still at the mechanics because the valve shim is tipping due to the cam regrind and a thicker shim, and the only recourse is either full billet cams or replace something with shim-under-bucket lifters as opposed to bucket-under-shim
Anyone know where I can get something to fix this issue?
"Don't go crashing into Vulvas. *Volvos"
Re: Shims lifting on angle due to cam regrind
Sounds like you've got two of the 3 fixes. Third is put smaller/factory cams in.
That's going to be a temp fix until I can find these little suckers locally
Oh, 4th option might be HLA that have been locked solid.
NB8A has hydraulic bits?
The guy who did the cam grind said "I had the most aggresive cam that BP engines could get (NB8A cam) and that the extra lift and more aggressive slope is tipping the shim. Is it possible at all he ground for a VVT engine? I can't for the life of me find an example online of that happening and listing symptoms.
You need these shim-under lifters to allow an NB to run aggressive cams. http://miataroadster.com/store/product/ ... make=MAZDA
Maruha/Tomei sell a similar set in Japan but they're much dearer and harder to deal with.
You would have to purchase these from Bill at MiataRoadster and then get your head guy to measure, locally order and fit the lash caps. Precision Shims in Croydon is one good source for the caps.
http://www.precisionshims.com.au/
thank you manga!
Precision in croydon can make a custom set for me, as long as I can give him the diameter of the lifter.
Loos like 45mm to me.
He can make a full custom shim under bucket lifter system? How does the cost compare with miata roadster units?
I thought he only made up sets of lash caps in accordance with sizes given by a head specialist. Are you sure he can make up solid lifters as well?
You're right.
He carries various buckets in stock though, supposedly.
Change of plan. We're machining the lip off the bucket, hardening it supposedly, and then machining an internal shim for each bucket.
- Vehicle: Non MX-5
this is what i did. used the same 2 suppliers. $200 for the lifters and 16x $5 for the caps.manga_blue wrote:You need these shim-under lifters to allow an NB to run aggressive cams. http://miataroadster.com/store/product/ ... make=MAZDA
- Vehicle: Non MX-5
sounds sh*t...22Silver wrote:Change of plan. We're machining the lip off the bucket, hardening it supposedly, and then machining an internal shim for each bucket.
project.r.racing wrote:this is what i did. used the same 2 suppliers. $200 for the lifters and 16x $5 for the caps.manga_blue wrote:You need these shim-under lifters to allow an NB to run aggressive cams. http://miataroadster.com/store/product/ ... make=MAZDA
I'll remember that.
The stupid cost of the Jap SUB conversions have been a big limiting factor in my caring if I put in bigger cams.
$200 plus getting shims locally in the right sizes is much better.
Users browsing this forum: No registered users and 52 guests
